- First Name
- John
- Joined
- May 26, 2024
- Threads
- 71
- Messages
- 838
- Reaction score
- 1,178
- Location
- Spokane WA USA
- Vehicle(s)
- 2024 Ranger Raptor Velocity Blue (fastest color)
- Occupation
- Retired aircraft tech
- Thread starter
- #1
I want to add a weBoost Drive Reach Overland cell booster to my RR, mounting the antenna on my truck cap is straightforward and easy. Where would be a good place to mount the inside antenna? It must be “at least 18” but no more than 36”” from the phone(s). That is pretty limiting, considering the lack of free dash space above the center display stack on my Raptor.
How about on the overhead console? But where exactly??? Maybe above the headliner itself, directly between the front seats and directly over the center armrest?
I usually travel with my iPhone resting on the Ford OEM magnetic charge pad, so that is another factor. I need a reliable cell signal in that location especially, so that my GAIA and OnXOffroad navigation apps will work better (especially streaming new, not downloaded, map data from my iPhone). If that spot needs a different antenna location, I would be willing to use my iPhone as a hotspot so my wife could use hers from the passenger seat.
Comments and advice from somebody who has successfully installed a cell booster would be greatly appreciated! Is there a better product in this price range, under $500? I have used a different factory installed weBoost in a travel trailer and it was a dismal failure, but that was probably due to a poor antenna choice (a magnetic stubby) and a partly blocked location in the roof. I think that setup would have been acceptable with a 20 foot mast mounted antenna…
EDIT: I suspect that the “more than 18”” spec is to reduce your constant exposure to radiated energy, but if the phone is positioned way down low, the antenna could be right next to it without frying my brain.
Thanks,
Thanks,
