Non Powered Pass Through Wiring
Bounty
Louisville KY
2026 Ranger Rapture
Just took delivery of 2026 RR last Monday. I have owned four Rangers over the last eight years. This is my first RR. I am trying to locate the pass through wiring that is for connecting accessories from inside the cab to the up switch wiring next to the battery. I have located those with no problems, but for the life of me I can’t find the non powered pass through wiring. I believe the inside wiring is located behind the kick panel passenger side at glove box (haven’t looked yet). I keep reading the under hood wires are passenger side next to the battery. Well, the battery is on the driver side so there is that. If one of you experienced owners could help me out, I would greatly appreciate it. Thanks in advance!
bgn
Seattle
2022 Maverick Lariat FX4
I just passed an antenna wire through the firewall on the driver side. Look directly behind the battery. There's a rubber plug with two parallel rubber strips on it. I pushed the cable through a hole in the grommet.
Bounty
Louisville KY
2026 Ranger Rapture
Thanks. I was hoping to use the factory wiring in conjunction with the upfitter switches. Just can’t locate the wiring. Pushing through the firewall is my fallback plan.
