Power On / Engine Start Chime Sound Not Working – 2024 Ranger Raptor
shawn
son
korea
ranger raptor
Hello everyone,
I’m having an issue with my 2024 Ford Ranger Raptor 2.0 Diesel.
The “chime” or welcome sound that normally plays when I turn on the ignition (power on or engine start) has suddenly stopped working.
Here’s what happened:
A few weeks ago, I tried installing a start-stop (auto stop & go) module and temporarily disconnected some fuses and wiring around the BCM area.
After that, I removed the module and restored everything back to its original state.
Since then, the power-on / engine start chime sound has disappeared.
  • Battery voltage is normal (no low-voltage issues).
  • All other sounds (indicator, seatbelt, parking sensor, audio, etc.) are working fine.
  • No DTCs related to IPC or BCM were found on FORScan.
  • I already tried battery disconnection and fuse reinsertion, but the chime still doesn’t return.
It seems like the IPC (Instrument Panel Cluster) or BCM may have muted or disabled the chime function after that module was installed.
Could this be fixed by performing an IPC module reset or reinitialization using FORScan or IDS?
Or is there a specific configuration (As-Built data) related to the “Power On Chime” that I should check?
Any advice or experience would be greatly appreciated.
Thank you!
stuartmunto
Stuart
Perth, Western Australia
2023 Ford Ranger Raptor
Most people would be happy to have a muted start up chime. Otherwise, you can always restore the BCM or IPC asbuilt files back to factory default by downloading from this website below - just enter in your VIN to pull the factory default files for your Ranger:
https://www.motorcraftservice.com/AsBuilt
