Trucks first problem (kind of..) - Auto Start Stop not working
Phlfwd22
Matthew
Tampa
Firefighter
My auto-start/stop doesn’t seem to be working the last few drives.
I know most people on here would see that as a good thing but I’d actually like it to work (I don’t mind pressing one button to deactivate it)
anyone else have this problem? I live in Florida and it has been 95-98 degrees the last couple of days so not sure if the truck has an issue or if it’s not going into auto stop to keep the engine fans running
Bmadda
Wisconsin
6gBronco, 4gBronco
Mechanic
Probably needs to keep the a/c compressor running...there are all kinds of parameters that lock it out
Phlfwd22
Matthew
Tampa
Firefighter
the a/c was off both times (I drive with windows down)
Bmadda
Wisconsin
6gBronco, 4gBronco
Mechanic
UUUGh...my bag is floating in my undies just thinking about it! Either way I wouldn't sweat it (see what I did there?)...it will ASS when it feels like ASSing!
Grabber
NJ
2025 Ranger Raptor, 2020 Super Duty Tremor & 2009 GT500
Start/stop is controlled by the ECM, engine has to be within it's paramerters to activate. My wife's Lincoln Aviator with same engine does the samething. Honestly I hate the start/stop function.
Raptor1996
Anton
Ohio
if its really hot outside the engine won't shut down to keep the coolent circulating and the fans in high power mode.
Phlfwd22
Matthew
Tampa
Firefighter
stuartmunto
Stuart
Perth, Western Australia
2023 Ford Ranger Raptor
Probably the ambient temp is too high - needs the engine running to keep the cooling system active... Turbos need oil circulating to cool down too so just let the car do it's thing - it knows what's best for it (or it should with all the sensors and computers)
Stop/Start system in an engine like this makes little sense anyways - much better to just leave it running unless stopped for extended periods. The Stop/Start is just there as it needs to be to meet emission regulations
John E Davies
Spokane WA USA
Retired aircraft tech
I am sure others would really like to know, you have a RR, do you have breathable seat covers? Use a beach towel? I am having a really hard time accepting driving around at close to 100 degrees on unventilated leather with the AC turned off… and why do you do it in the first place? It is very hard on the leather itself. Thanks.
John Davies
Spokane WA
fordtrks4ever
Tim
Perkiomenville, Pa
Also if the battery is below a curtain charge the start/stop will not work due to charging of battery by alternator.
Phlfwd22
Matthew
Tampa
Firefighter
John Davies
Spokane WA
if I have my daughter with me I’ll drive with windows up and ac on but when it’s just me, I prefer the windows down and feeling the wind (on that note, I really like the electronic sliding rear window on this truck for the wind to pass through with less drag). I don’t turn the ac on with the windows down cause it doesn’t make a huge difference to me and might save me a couple mpg’s ?
jeffers
Jeffrey
Nevada
2024 Ranger FX4, Mk7 GTI
I find if I turn it off on startup and then turn it back on in a few minutes, it doesn't come back on.
Phlfwd22
Matthew
Tampa
Firefighter
I didn’t realize there was a dash menu for auto start stop.
Conclusion… it says outside temp is too high to turn the engine off.
so all of you complaining about the auto start stop or buying kill switches or tunes for this.. just move to Florida instead ?
