Radio volume loud at start up
Tarfu
canada
2025 xlt fx4
Anyone having issues with the radio volume? I make sure to turn the volume down to 2 or 3 when I park and when I start it again the volume is set at 6. If there is a setting I cannot find it. I did a hard reboot of the display and it stopped for one start up then started doing it again. Any thoughts? My truck is a 2025 XLT with tow package and 301a package.
LeeHo
Lee
Niles, Mi.
Check your settings. There might be an adjustment for automatic volume control. It is intended to adjust the volume up or down depending on cabin noise level. I have not used it myself but I know it is in the lariat so if you have the upgraded electronics it should be in yours.
Meatbag
Illinois
2025 Ranger XLT 2.3 4x4
Picked up my 2025 XLT last Friday. 200 miles on it.. Mine does the same exact thing as yours. I think mine defaults to 7 volume on each start up. I turn it down to 2 or 3 then shut off and turn back on and truck remembers it for a cycle but on the next time it goes back to 7.
I've done the restart trick to get the touch panel to reboot but that didn't fix it. There are also no audio settings that will fix this. I've gone through the menu meticulously.
Tarfu
canada
2025 xlt fx4
I even contacted Ford and they acknowledged the problem but there is no setting or fix for this that they know.
