rear sway bars, or anti-sway bars, depending on where you are from
Aircraft examiner
so, hellwig has their rear sway bars listed as fitting 19-25. i don't see a reason to not believe them as the trucks look awful similar from the underside. what do you guys think? i am going to add a rear sway bar because its terribly windy where i live so it should help with the rocking on the highway and my truck is 2wd so i am not worried about how much flex i get off road. i also prefer to have a great handling on road vehicle anyways and always add sway bars to my vehicles that are missing them.
i wonder if the bronco has a rear sway bar and what size its front sway bar is? on my 04 ranger, the front sway bar from an explorer is a huge upgrade and the rear sway bar from a bronco2 is an upgrade. some older rangers also did not have a rear sway bar, like the new rangers are missing them but mine had both. anways, i would hope the bronco ones would be upgrades to our trucks but until the start becoming more common, i geuss it will be slow finding out info on them.
They changed the suspension on the 24/25 so it might not fit. Not sure if they changed the position of the sway bars though.
Aircraft examiner
i was looking at their sway bar and mounts and it seems like it would work because its a generic looking bar and mounts that just clamp to the frame and rear axle housing. i would think the end links probably changed a little in order to adjust for the width change on the frame. or maybe they just connect on the outboard side of the sway instead?
i read that the gen5 ranger guys who got the rear sway bar said it made a huge difference
