Replacement BeadLock Ring
cozzishc
Stephen
MA
I am looking to replace the heavy BeadLock Trim ring with a lighter, plastic or resin ring to reduce weight. Was speaking to someone on Ranger 6G but never heard back. Does anyone have any insight or info on what/how I can replace the metal rings with a lighter material?
Might look around for Bronco rings, they are interchangeable with the Ranger rings.
cozzishc
Stephen
MA
They are the essentially the same heavy rings!!!
Yea I have never seen what your after before. the regular stock rings are aluminum. I just thought their might be more aftermarket options out there marketed for the Bronco, if there was such a thing as a 3D printed ring that would fit it would probably found on the Bronco side of the market.
The Bronco has a much larger US aftermarket footprint then Ranger, a lot of the Ranger specific stuff has been developed in Australia. A lot of it still has to be imported from Australia.
