I've run across occasions where the A.I. search info was mostly wrong sprinkled with an occasional correct piece of info, so I have a tendency to just do my own research when I have time.
The mixed gear ratio and the rear differential as being an M220 in particular, caught my eye as incorrect. I don't think the exhaust will be much of an issue and the added front end weight shouldn't be much of an issue either. The weight difference between the 7.3 and 3.0TT is in the neighborhood of 100 - 150 lbs.
Yea, we discussed the weight difference and based on my setup and use case scenario we really don’t see any need to modify the suspension. Time will tell, but to me I just can’t see that minimal amount of weight difference ever causing me any issues or concerns.
If there is a problem , I believe there are some heavier springs available.
I didn’t know about the AI part of that info till there was some cleanup / clear up post going on in the Bronco forum. I agree AI is handy at times , for sure not something we can rely on, given the amount of errors that seem to occur.
