Caleb@PandaMotorworks
Gold Sponsor
Caleb
St Louis MO
2021 Bronco / 2022 Maverick EcoBoost
Ford Ranger The Panda Power Module is HERE! Ranger Raptor 3.0L Tuning Solution by Panda Motorworks! PrintTest_To
We are excited to introduce our Panda Power Module tuning device for the Ford Ranger Raptor! This small, plug n play module packs a HUGE punch and is a performance upgrade that every Ranger Raptor owner should consider. Backed by our years of EcoBoost calibration knowledge and dyno-proven results, your Ranger Raptor will see gains up to 12% while maintaining OEM Reliability. This device is super simple and installs in minutes. To make operation even easier, a dedicated app allows map switching via Bluetooth.
Ford Ranger The Panda Power Module is HERE! Ranger Raptor 3.0L Tuning Solution by Panda Motorworks! IMG_1019
We codeveloped this device with the user in mind, that’s why we retained all OEM failsafes to keep reliability in check! Another point of reliability we wanted to focus on was the transmission. For this reason, we made sure the increased power delivery was safe for all driving conditions. The best part about this device is the fact that it keeps your factory warranty in tact! If you need to take your Ranger Raptor to the dealership for any warranty claims, simply uninstall the device completely and no trace is left behind.
Ford Ranger The Panda Power Module is HERE! Ranger Raptor 3.0L Tuning Solution by Panda Motorworks! IMG_1022
This device isn’t just for those who want their Ranger Raptor to be faster. If you added a heavier wheel and tire package or if you plan to take your Raptor off road, this device is for you! Let’s be real, tires are HEAVY! If you add larger tires, you may notice a bit of power loss. This is because the engine must work that much harder to turn the wheels. With the Panda Power Module, you will recoup that power loss and then some! Plus, who doesn’t want a little extra power and torque?!
To help keep this added horsepower and torque in check, we added a set of NGK 1 Step Colder Spark Plugs to each Panda Power Module kit! When increasing the boost pressure on any EcoBoost vehicle, the stock spark plugs will experience what’s called Spark Blowout. This is because the stock plugs are too hot and do not experience a complete burn. By going to a 1 step colder spark plug, you experience a more complete burn which results in consistent power delivery. This combined with the greater knock prevention that these plugs provide results in increased reliability.
Ford Raptor 3.0 EcoBoost
Stock: 392 HP 430 TQ
Optimized: 436 HP 488 TQ
I’ll go ahead and answer what we anticipate will be some of the most frequently asked questions:
What exactly is a Plug-n-play module and how does it work?
A plug-n-play module checks the OEM sensor data and configures the signal safely and reports back to the sensor. In turn, this is how we are increasing the power and torque of your Ranger Raptor! From the outside looking in it seems very simple, and it really is! We put a lot of time and effort into making sure the user experience is very simple and rewarding. This leads me to another question:
How exactly did you develop this device to make power safely?
We used our years of EcoBoost calibration knowledge to safely configure the signals in a way that won’t upset your Ranger Raptor! All changes were made within the limits of the factory ECU so that your Raptor will receive these reconfigured signals in a way that it can safely react to. This will prevent any damage to any drivetrain components and prevent your Raptor from entering Limp Mode or displaying a Check Engine Light. We utilized our OEM data-logging capabilities during R&D to ensure that the Ranger Raptor retained factory drivability. We made sure that Air/Fuel ratio remained within a safe limit, as well as timing advance to deliver an OEM+ driving experience! For more on our tuning, check out our Blog by clicking HERE!
SubaruRaptor
Jory
North
I mean its a bit of misnomer when you say it keeps your factory warranty in check since you have to remove the device for that to occur. At 600 dollars, there is basically zero reason to buy this as the FPT tune gives you more power and is only 200 bucks more.
Gold Sponsor
Caleb
St Louis MO
Being this device can not be traced it does keep your warranty intact for the full 5 years 60K unlike the ford performance unit which lowers your warranty to 3 years 36K.
This is the main reason we have this device, so people can get a good boost in power without worrying and if they are not worried we have other options coming to market soon
How did you crack the ECU when Livernois is still writing on it?
Deleted member 9086
It’s a piggyback or if you prefer a “sensor fooler.“ Doesn’t require access to the ECU, access ECU programming or the ability to change the ECU mapping.
All piggybacks, modify sensor input signals and not internal ECU mapping. ??
SubaruRaptor
Jory
North
The tune doesnt no lower your warranty to 3 years. The tune comes with a 3 year warranty.
Gold Sponsor
Caleb
St Louis MO
Exactly because your factory warranty is now void. Its being replaced by a separate Ford Performance 3 year warranty.
SubaruRaptor
Jory
North
Its not lol. your factory warranty is retained. There is a monsterous thread on this here. The tune has a warranty, and you have your normal warranty. The only warranty you would lose is your extended warranty.
Gold Sponsor
Caleb
St Louis MO
Our understanding regardless of thread is very different from our understanding. Please see below
Ford Performance and remains in effect for the balance of 36 months or 36,000 miles / 60,000 Kilometres, whichever occurs first, calculated from the start date of the manufacturer's New Vehicle Limited Warranty.
I
f you want clarity then I would talk to your installing dealer for any Ford ProCal
Deleted member 9086
We have fully researched the FP warranty. Your comments are simply incorrect and your understanding is contrary to the factual information.
“The 3/36 warranty from FP; is for the tune and tool only.“ It doesn’t affect the in place OEM factory warranty or the owners purchased extended warranty. Nor does it take the place of either.
Additionally, I have posted the direct response email from Ford Performance and their supervisor, to back up the comment.??
Raptor_joy
Does your device require the use of premium fuel?
