Upgrading to adaptive cruise control to a '24 XLT?
Mr T Dog
Tom
Chesapeake
O.R. Systems Specialist
Hey Wubster100 -
Thanks for all of that info and the work you put into it. The link to the new Ranger thread was very helpful as it is dealing with exactly what I'm interested in doing. Looks like things are generally still developing on that front.
If anyone else is interested or curious, here are the links provided by Wubster100. Thanks again, W.
Previous generation ranger where ACC was added:
https://www.ranger5g.com/forum/threads/adding-adaptive-cruise-control.9057/page-5
ACC for 6g Ranger:
https://www.ranger6g.com/forum/threads/adding-adaptive-cruise-control-acc.10734/
lourenco
2025 Ranger XLT 2.3L RWD
IT
I succesfully added Adaptive Cruise Control with lane centering along with the steering wheel control to my 2025 Ford Ranger XLT with the new 2.3L engine.
Forscan Coding:
(Note: I used the F150 Forscan Coding shown below, but I had to make a few small changes that are not shown below. I will update this coding later today - 3/30/2026)
Please backup and save all the coding for the modules below.
SCCM *Only if you swap the left hand steering wheel switch for the one that includes the follow distance change.
724-03-01 04xx xxxx
ABS
760-03-01 *xxx -- (4 to C)
IPC
720-01-01 x*xx xxxx xx-- (C to F)
720-01-02 xxxx *x-- (4 to 8)
720-03-01 x*xx xxxx xx-- (0 to 5)
720-03-02 xx*x xx-- (4 to C)
720-09-01 *xxx xxxx xx-- (A to B)
720-09-01 xxxx xxxx *x-- (1 to 9)
720-09-02 *xxx xx-- (0 to 2 or 1 to 3)
720-10-01 x*xx xxxx xx-- (A to B)
(Note: Missing Speed Limit Sign Coding to Show Speed Limit Sign Graphic on the Gauge Cluster. I will add the coding for this later today 3/30/2026)
BCM
726-16-01 xxxx x*** xx-- (384 to 390)
APIM
7D0-05-01 *xxx xxxx xx-- (0 to 2)
7D0-05-01 xx*x xxxx xx-- (0 to 8)
7D0-09-01 *xxx xxxx xx-- (4 to 6 OR 5 to 7)
7D0-09-01 xxxx *xxx xx-- (2 to 4)
7D0-09-01 xxxx xxxx x*-- (set to B)
7D0-09-02 xxx* xxxx xx-- (4 to E or 5 to F)
7D0-09-02 xxxx x*xx xx-- (4 to 7)
7D0-09-02 xxxx xxxx x*-- (5 to D)
7D0-09-04 xxxx xxxx *x-- (0 to 6)
IPMA
706-01-01 *xxx xxxx xx-- (0 to 8)
706-01-01 xx*x xxxx xx-- (0 to 5)
706-01-01 xxx* xxxx xx-- (0 to 8)
706-01-01 xxxx xxxx x*-- (A to E)
706-02-01 *xxx xxxx xx-- (3 to 7)
706-02-02 x**x xxxx xx--(04 to 05)
706-16-01 *xxx xxxx xx-- (0 to 1)
706-16-01 xxx* xxxx xx-- (9 to B)
IMPORTANT: Disconnect FORScan and turn the truck completely off, then back on. Reconnect FORScan BUT do not use the saved profile. Let it rescan for all modules. The CCM Module will be shown after the full rescan. If you use a saved profile, you will not see the CCM Module.
Connect to the CCM module to program module with your truck's vin number.
** Note: I need to verify the CCM coding below is valid for the Ford Ranger. I only updated the CCM module with my truck's vin number. **
764-01-01 xxxx xxxx xx-- (Not Verified)
764-01-02 xxxx xxxx xx-- (Not Verified)
764-01-03 xxxx xxxx xx-- (Not Verified)
764-01-04 xxxx -- (Not Verified)
PSCM
730-02-02 xxxx **xx xx-- (00 to FF)
730-02-02 xxxx xx** xx-- (00 to FF)
730-02-03 **xx xxxx xx-- (00 to FF)
Once the coding is done, CLEAR ALL DTC, and calibrate the CCM.
Note: The front collision system is disabled until the CCM is calibrated. You will see this error message on your gauge cluster.
CCM Calibration:
In Forscan, go to the wrench icon on the left to get to the service menu and select CCM Calibration. This will require you to drive around for around ~10-15 minutes for the CCM module to calibrate. You will see a message like CCM Requires Alignment on the gauge cluster during the calibration process.
Note: Towards the end of the calibration process, Forscan will stay at 99% Calibration Completed for several minutes, which is no cause for concern.
Once CCM calibration has finished, the front collision system will function along with the adaptive cruise control. If you have not installed the left steering wheel adaptive cruise switch, you have (3 Bar) following distance that you can't adjust.
Parts List:
CCM Distance Sensor - $125 (Used CCM on eBay from a 2023 F150)ML3Z9E731E or Search for ML3T-9G768-AL (Engineering Part Number on Label)
CCM - Connector Pigtail - $12WPT-1198
CCM Bracket - $136.46N1WZ14C022G
CCM Bracket Bolts Left and Right (Pack of 4 - Only need 2) - $10.40W718083S450B
CCM Bracket Bottom Bolt?
CCM Black Plastic Cover - $29.45N1WZ14C022F
CCM Cover Push Pins (Pack of 4 - Only need 2) - $10.40W714415S300
IPMA - Pin Wire Connector (Pack of 5 - Only need 4) - $33.02WT1002
IPMA to CCM Wiring - 4 Conductor Electrical Wire ~18AWG (CCM +, CCM -, CCM CAN Low, CCM CAN High)Amazon
Left Steering Wheel Switch for Adaptive Cruise Control (Optional for adjusting following distance) - $65.00N1WZ9C888D
