Valve stem or cap recommendations
eyelise
NorthEast
2015 Ram1500 Reg Cab 5.7L/8spd
Anyone else find it hard to check pressure on the beadlock wheels. The valve stem is hard to reach. Maybe just a new cap would help. I bought a locking gauge and filller which work great. Just can’t get my fat fingers in there to take the cap off.
eyelise
NorthEast
Ordered those and a few others. There are two different types those that require removing the OEM valve and those that are meant to be "pass thru". Also some did not work with typical tire guages and others needed special caps. After a bunch of ordering and returning the brand Milton worked perfectly. They are pass thru, standard gauges work fine, and standard caps fit.
Mgrmax
Detroit
Which Milton extensions did you order? Thanks
eyelise
NorthEast
I found them on Amazon only one type listed
