GregFoutz
Greg
Mesa, AZ
F150 Raptor, Bronco Raptor
off-road geek
Hey Guys
we just got our Ranger Raptor adjustable bump stop kits finished and releasing now. Several people have been asking about these so I thought it would be best to post it here for everyone to see.
we have a front kit that will work with the stock front lower arm that has a clamp mount that goes on the arm that gives you the bump pad and also limit strap mount. The bump stop mounts to the frame and is a weld on mount kit but you can use Fox, King, ADS, or Carbon 2"threaded body bump stops.
The rear kit also uses the same bump options with a Fox, King, ADS, or Carbon 2" threaded body bump stop that can be adjusted in height to help if you want to run a bigger tire to keep it out of the upper fender well. The mount bolts to the frame with existing holes. The lower bump pad bolts to the stock rear axle for the bump pad section. Easy install but does require a small trim on the under bed sheet metal that crosses over between the fender wells. very minor but has to be trimmed.
you can check them out here for more info. First production runs are going though the shop right now so these will start shipping first batch in the next 2 weeks but we have a very limited quantity in that first run. We will do more on the next batch but the first group will go fast so if you have been waiting for these i would suggest you jump in quick and get your orders in.
https://www.foutzmotorsports.com/co.../2024-ranger-raptor-adjustable-rear-bump-stop
https://www.foutzmotorsports.com/co...r-front-limit-strap-bump-stop-stock-lower-arm
TenTenths
Scott
Snohomish, WA
Awesome! This was one of those items that the Bison had on my list over the Raptor when checking boxes. This levels that playing field. Combo price when bought together or do you guys offer a forum discount?
GregFoutz
GregFoutz
Greg
Mesa, AZ
off-road geek
rxv_poor
Leland
Tucson AZ
2016 Subaru Forester XT
IT
I appreciate all of your hard work in developing all this cool stuff. Unfortunately it's killing my wallet :)
RedNose1
Saud
Dubai
Ranger Raptor 2023, Gen 3 Raptor
Hey Guys
Thank you for all the R&D and hard work you guys put for us to enjoy our trucks , even if we were on the other side of the world.
Do you guys have any pictures of the kits installed on a truck?
And if yes , can we see them please ?
GregFoutz
GregFoutz
Greg
Mesa, AZ
off-road geek
We are doing another install this week at the shop and I will post some pictures
Ivan Baez
Ivan
Queretaro
2023 ranger raptor
Harman
looks interesting, thanks for sharing.
Is this for hardcore off road only?
GregFoutz
GregFoutz
Greg
Mesa, AZ
off-road geek
The hydraulic bump stop helps absorb bigger bumps whether off-road or on road. It helps support the existing shock and takes away the harsh bottom out.
