17" Beadlock Capable Wheels Worth The Cost??
Order Beadlock or Not To Order Beadlock?
  • Total voters
CherryCoke
Las Vegas
Drinking CherryCoke
As an option on the Ranger Raptor for $1,495, is it worth it?
In my situation as I plan to go 315/70R17 (aka 35s) I want to have at least +25mm offset. I understand there might be some trimming to be done, but I have heard +25mm offset is where you want to be. IMHO, not worth it as it comes in a +55mm offset. There are plenty of equally priced or in some cases budget friendly bead lock wheels on the market that give you more functionality and/or more capable out the box. To add you will also need to buy Ford's Functional Bead Lock Ring Kit that goes for $1,110 if you plan on utilizing the bead lock capability.
Even if you stay with the stock tire size, I still believe it's not worth the cost. Just my opinion. :)
What do you think???
- Would you get them anyways.
- The price is right.
- I don't care, it looks cool.
- I never run under 20psi when off-roading.
Ford 17" x 8.5 Bead lock Capable Alloy Wheel
Offset of +55mm
Weight ???
Ford Ranger 17" Beadlock Capable Wheels Worth The Cost?? FordMY22RangerBeadlockCapableWheel17withBeautyRingSETOF4_1024x1024
pyates999
Paul
West Virginia
2004 F150
Foreman
I don’t need nor do I care for the look of the Ranger Raptor bead lock capable wheels. That being said though, I do like the Bronco Raptor bead lock capable wheels. I can’t really say why but I do & if they will fit the Ranger, I would seriously consider a set. I see Bronco Raptor bead lock wheels for sale from time to time but would never purchase them from Ford as they are $1150.00 each!!
CherryCoke
CherryCoke
Las Vegas
Drinking CherryCoke
Bronco, Ranger, Ranger Raptor all share the same bold pattern at 6x139
Bronco Raptor variants, I believe is 6x135 - So may not fit (Updated :) )
Bronco Raptor bead lock wheels are 17x8.5 with +34offset and weight about 36.4 lbs. You might get away on fitment with an added 5mm or 10mm hub centric spacer. I personally would not go any more than 10mm, at that point you're best getting different offset wheels.
As for the stock 37" tires that come on the Bronco Raptor, those won't fit without a lift kit.
MackDaddy
MackDaddy
Flexico
your girl's nissan altima
Pornstar
I opted out of beadlocks. For the extra price plus the additional kit needed I figured that I would just buy a set for another one of my vehicles. Thinking of making an offroad mustang or charger build
Wayfaring Ranger
STL
They look really nice but if you aren't going to be airing down often and you aren't rich it doesn't seem worth it.
pablo94sc
Focus
I don't think I need them as I don't plan to air down enough to justify them. If I do decide I need something more capable, Method's bead grip seem like the way to go, and they look good too
Bonus Oz
Bruce
Cairns Australia
23 Raptor , 72 Escort RS , 89 Sierra Cosworth , 60 Mini Cooper, 72 Mini Hayabusa
Wheeler Dealer
I've never lost a tire so didn't care for expensive security to make sure they stay on the rims...
Slappybabs
NJ
2017 gt350
I didn’t think they were worth the 300+ per rim when you can get an arguably better looking wheel for half that price. JMO
ivotuk
Ray
North Pole, Alaska
2019 Ranger Lariat
IT
I don't like the look. They look like cheap beadlock knock offs.
RacerX
Bronco
Bronco Raptor uses F-150 bolt pattern, which is different from other Bronco trims and Ranger trims.
Ranger Raptor ROW wheels (should be the same as the wheels we'll see in USA) fit Broncos
https://accessories.ford.com/2021-bronco-17-x-8-5-wheel-kit-dyno-gray
17" x 8.5"
6-lug, 139.7mm bolt circle
55mm offset
So, Bronco Sasquatch/Wildtrak/Everglades wheels should bolt up to the Ranger Raptor
https://accessories.ford.com/2021-bronco-bead-lock-capable-wheel-kit-wildtrak
17" x 8.5" wide
30mm Offset
Fitting is a different question... but the 30mm offset of the Sas wheels is close to the 25mm the OP was looking for.
