2024 OEM Fog Light
Richiep124
Richie
I just noticed the driver side fog light on my 2024 Ranger XLT is not working. I looked at the housing from underneath the truck. Is there a fuse or something in the housing itself that would cause it to not work. I mean it's a factory LED so it shouldn't burn out. Anybody ever had to replace one of these??
ChronciallyChronic
Central Florida
2024 Ford Ranger Lariat
You're under warranty, have the dealer shop figure it out. BTW, with you have a bad connection (the fuse will run both fog lights) or the LED has failed. Replacement is the entire unit.
ATXian
ATX USA
'25 XLT V6
Are you sure it's truly not working and not just that it's functioning as a cornering light?
Cosmic
Chris
Idaho Falls, ID
What was your solution to this? I just noticed that my fog light was not working same one driver side. Same type vehicle and year.
Sauce
Northeast
2025 Ranger XLT FX4
When you test it - make sure the steering wheel is dead straight. As someone else said, the cornering light feature can make it look like its out if the wheel is turned. Happened to me too.
BigOleOgre
Nate
STL MO
Field Service Engineer
^ 100%
