2025 Model Rangers have different ABS as build data. Spreadsheet is outdated.
egecikrikci
Ege
Turkey
Ford Ranger Wildtrak 25'
I’m documenting this to raise a flag for everyone working on FORScan modifications for the new 2025 Ranger (Wildtrak, Raptor, Tremor). The standard ABS as-built spreadsheets we’ve all been using are now officially outdated and incompatible with 2025 models.
Context:
I was trying to enable Lane Centering and Intelligent Adaptive Cruise Control (with Stop & Go) on a 2025 Wildtrak (base trim) here in Turkey.
This means some previous configurations and bytemaps for ABS features possbly are broken for 2025+ models. Do not try to reuse them directly.
What I found is that Ford changed the ABS module data layout in 2025 Rangers:
Legacy Format (2024 and prior):
  • 760-03-01: Only 2 bytes → xxxx xx
  • No 760-03-02 block at all
2025 Format:
  • 760-03-01: Now 3 full bytes → xxxx xxxx xxxx
  • New Block Added: 760-03-02 (2 bytes)
Every 2025 I checked at https://www.motorcraftservice.com/AsBuilt/ has this new 760-03-02 (2 bytes)
760-03-01 used to control:
  • Trailer Brake Controller
  • Trail Control
  • Reverse Brake Assist
  • Lane Centering
  • IACC (with Stop & Go)
Now the bit positions and control logic are relocated and restructured, possibly across 760-03-01 and the new 760-03-02.
I cross-checked:
  • 2025 F-150
  • 2025 F-250
  • Maverick (from 2023 models and onwards has 760-03-02 but format still differs its full 12 digits)
so to this day after 2 days of research I haven't been able to decode what this stands for.
I assume there are more changes with 2025. If you guys have seen 760-03-01 (12 digits) and 760-03-02(2digits) format before please hit us up so we can debug it.
