SPVPARTS
Greenwood, IN
Ford Raptor/Bronco/Mach E
Sales
Some of you may know us from the F-150 Raptor & Bronco Community...
(If you do, CHIME IN HERE! We would LOVE to hear from you!)
If not, you can check out several of our products which we will be working on new variations here on YOUTUBE-
(Videos Link)
We do OWN a 2025 Ranger Raptor...
We are currently solving the "Everywhere switch wire" issues...
We will have OEM Like applications for lighting, such as A-pillar, Fog, Light Bars, rear lights, etc.
In fact... in about a week the new REAR kits will be released...
Here are a few sneak peaks...
After some looking. We found the perfect spot that doesn't interfere with the tow hooks or exhaust and created a new mount!
If you are interested in these kits, feel free to reach out to us now and we will reserve one for you before they post publicly!
The rear kits will be available with the following lights-
Baja S2
Baja S1
Rigid SRL
Diode SSC2
Diode C1 and C1R
Just like the F-150 and Raptor versions (seen in the videos) you can chose from 3 options with our plug n play fully patented harness system!
Automatic Triggers (and Red Backlight with Tail Lights with certain lights) With our patented Plug N Play Tail light adapter...
To Switch
Or both
Ford Ranger Several New Products COMING!! (Check out new and upcoming from SPV Parts!) 113
Ford Ranger Several New Products COMING!! (Check out new and upcoming from SPV Parts!) 112
Ford Ranger Several New Products COMING!! (Check out new and upcoming from SPV Parts!) 111
When it comes to Grille Lights...
I know many of you have expressed a desire for those. Unlike other companies that just repurpose cheaply made trailer universal marker lights. We actually design and produce some specific. We are working on that now. We want your Raptor to look like a RAPTOR!
Please feel free to reach out to us at info @spvparts.com
or call or text us at 317/934/6778
Visit us at: specialtyperformanceparts.com
We would love to hear your ideas and what YOU would like to see for your Ranger Raptor!
moproblems
SW MI
Can't wait for a grille light kit that is plug and play into the headlight harness. You can put me down for one.
Any chance we could get a kit to bring back the high beam activation for AUX5 and/or AUX6? An external relay would be fine, it would be nice to have that option.
SPVPARTS
SPVPARTS
Greenwood, IN
Sales
The Aux wires? Yeah, that is a mess. I am looking at how to fix it. The issue is Ford decided to skip doing the American made truck like the rest of the line over here and they literally imported the Australian version and simply swapped the sides of the steering column. That left all that European odd wiring and harnesses in place. Even the connectors for tail lights and stuff are the Euro ones. Unlike the other Rangers...
Reactions: Doc
moproblems
SW MI
I think there is a misunderstanding... On USDM raptor all aux switches are independent of any of the other lighting switches. On ROW trucks AUX5 and AUX6 are enabled only when the high beams are on. I'd like (and there are a few others in a thread on this forum) that would like a way to restore the ROW functionality so that my lightbar works with the Auto High Beam function in the truck.
SPVPARTS
SPVPARTS
Greenwood, IN
Sales
Check out what we did with the Bronco in the videos below..
We don't use scotch locks. We use the same connectors Ford uses on the vehicle, as well as other waterproof connectors on our harness system.
Reactions: Doc
moproblems
SW MI
Oh I know, that's why I'm excited you guys are coming out with something for us.
Reactions: Doc
SPVPARTS
SPVPARTS
Greenwood, IN
Sales
Gotcha.
I was referring to connections not being in the same places and spread out. Limiting access to each switch wire.
You basically want to have things turn on or off with high/low beams. Which may be a function easier with Forscan. Thats because typically those are things Ford turns on and off in the computer from different regions. Which is most likely the case. I will do some digging. If you want to email me any details into specifics to john @spvparts.com I can look deeper too.
Reactions: Doc
Sauce
Northeast
2025 Ranger XLT FX4
MoBob
Bob
Ofallon MO
2023 F150 Raptor, 2024 Ranger Raptor
Damn it took you guys a while to get on board. I'm glad , I can finally quit listening to the wifey complain about not having proper lighting on the little Raptor and I don’t have to put in a cheap half assed solution for her like I see from other vendors. I can quit sending those monthly emails too.
Reactions: Doc
GLT
2024 Ford Ranger Raptor; 2022 Ford F-150 Raptor 37
Really excited to see John and team at SPV moving into the Ranger space.
For those unfamiliar, SPV's products, ingenuity, engineering AND CUSTOMER SERVICE are absolutely top notch.
Slyder
Washington
KTM 1290R, '24 Ranger Raptor
Machinist
I was familiar with them from the Bronco G6 side and decided to go with them for the Rigid lights and their plug-n-play harnesses for the up-fitter switches.
I had originally intended to use the back-lighting feature of the Rigid 360's and ordered the harnesses required for that.
I then switched gears to go the up-fitter switch route because getting to the 360s to adjust them in the ADD Edge bumper actually requires you to remove the grill to access some of the lights screws or aim them.
SPVPARTS
SPVPARTS
Greenwood, IN
Sales
Indeed, it did... but it wasn't for lack of trying. Lol
It took FOREVER for us to get our truck. We had a 2024 on order for over a year before they finally allowed us to switch it to a 2025 instead of the 2024. Then, we waited another several more months on that one. So, we have only had the truck for a couple months now, but we are super pumped to get to work on creating products for you all.
I personally love our Ranger Raptor so much. John had to practically haul me out of it to take it from me for product development. So, I take the blame for us not having released anything yet in the past month or two. Everything prior to that was on Ford. Haha! 😜
If there is anything specific you would really like to get for your truck, please let us know and we will see if we can get it created for you!
Cheers!
Sidney @ SPV Parts
317-934-6778
SPVPARTS
SPVPARTS
Greenwood, IN
Sales
You guys have a really nice light bracket for the space on either side of the front cruise control sensor, but its for the 5g Ranger. Would love to see something like that for the 6g. I'm fabricating my own, but would love to buy something with your level of expertise and fabrication vs my jankiness!
https://specialtyperformanceparts.c...-light-no-drill-mounts-lights-sold-separately
I will put this on our list of possible kits for John to look at creating asap.
Thank you for the suggestion!
-Sidney @ SPV Parts
YukonRanger
Yukon
Right on, just ordered some lighting kits this should make things much easier to deal with during install
Reactions: Doc
el_sabio
Randall
Tennessee
24 Ranger XLT FX4
