TrailRax
TrailRax
Woods Cross Utah
All TrailRax products are up to 50% off, including the TrailRax Modular Roof Rack for the Ford Ranger 6th Gen. All Ranger racks are 30% off.
Save
$500 off Roof Racks for Ford Ranger 6th Gen
Shop Ranger TRMR
: https://trailrax.com/collections/fo...modular-roof-rack-for-the-ford-ranger-6th-gen
Accessory mounts for roof top tents, awnings, fuel, recovery boards, storage, lighting, and more are also on sale.
All mounting solutions for RTTs, 270° awnings, recovery gear, and fuel are on sale. This is TrailRax’s final and biggest sale of the year, so if you’ve been thinking about upgrading your Ranger or grabbing a gift for an off-road lover, now’s the time. These deals end December 1st, and products are moving fast.
The TrailRax Modular Roof Rack for the Ford Ranger 6th Gen is built for adventure — engineered, made, and tested in the USA. Designed to handle anything from daily drives to overland expeditions, it offers:
  • 650 lb static load rating and 350 lb dynamic rating — ready for tents, gear, or recovery tools
  • Adds only ~3 inches of height for a low-profile look
  • All-aluminum construction — lightweight, corrosion-resistant, and durable
  • Easy bolt-on install — no cutting or headliner drilling required; stainless steel bolts included
  • Wind deflector and light-bar cutouts built in for versatility
If you’re searching for a Ford Ranger roof rack with Black Friday deals, this is the one to grab. Whether prepping for winter adventures or just hauling gear smarter, this rack delivers performance and style.
Don’t miss your chance to gear up your Ranger 6th Gen while saving big this Black Friday.
clarke
Tennessee
2025 Ford Ranger Raptor
What kind of fuel economy and wind noise impact are incurred with the roof rack?
bdallas9
Washington
sales
Great question. I have one of the first racks to come off the assembly line back in early summer. I saw no real impact on my fuel economy. There is a slight amount of wind noise but that you will get with any roof top rack.
It’s 10x the other racks on the market. The TrailRax team engineered this thing to do the job(s) it was intended to do. Installation was super straight forward and can be done in your driveway or garage.
They also have been testing this design for over a year before coming to market. It will be a wise investment!
Hope this helps
clarke
Tennessee
Hope this helps
Think it would work for a canoe with a single full height cross bar over the bed?
TrailRax
TrailRax
TrailRax
Woods Cross Utah
Yes, a canoe could totally be mounted on the rack with a full height cross bar. With a dynamic weight rating of 350lbs, you could strap 2 canoes on!
pablo94sc
Focus
Looks nice. I'm not in the market yet, but will you be offering any options with cut outs or other mounting options for lighting? Sorry if I missed it earlier in the thread.
TrailRax
TrailRax
TrailRax
Woods Cross Utah
Yes, we currently offer the 40" light bar cutout wind deflector variant with the Ranger rack. Also, all of our roof racks provide 360 degree mounting, so you can mount lights on the sides, rear, cross bars as well. Check out our Dome Light Brackets - compatible with most small lights.
Dino Jockey
Ron
Alabama
New to roof racks so knowledge is limited….. what do u have to remove from the interior to install?
bdallas9
Washington
sales
Honestly, it’s not that bad. You’ll have to remove the a pillar covers, unbolt the four seatbelt bolts and pull down the weatherstripping around each door frame. That’ll allow you access to the headliner. And then you’ll be able to gain access to the four bolts holding the roof trim piece and then you can put the brackets in from there. But there’s a pretty good video on the Trailrax website that goes through the entire process. Also, if you follow them on YouTube, you’ll be able to see that walk-through on their YouTube page.
TrailRax
TrailRax
TrailRax
Woods Cross Utah
Here is the install instructions video for you! As Brian said, you do have to access the four bolts underneath the headliner temporarily. The rack is 100% bolt-on though, no drilling required.
ShadowDragon24
2025 Ranger XLT Fx4
Heavy Equipment Operator
Have any Canadian venders? website says you guys dont ship to canada 😭😭 and would this sale also go for them?
TrailRax
TrailRax
TrailRax
Woods Cross Utah
TrailRax
TrailRax
TrailRax
Woods Cross Utah
Can you make a shorter one that will fit with a GFC?
The tallest point of the roof rack sticks up 1/8th of an inch above the shark fin antenna in the rear middle. In the photo it looks like there is some clearance above the fin, so the current Ranger rack could fit - worth the measure! As long as you have clearance under that GFC, it should work. Keep in mind bed flex between the bed and cab of the vehicle.
