Wolfbox
Florent
CA
Ford Ranger
Attention off-road enthusiasts and overlanders! We’re thrilled to announce the launch of our all-new Wolfbox HyperFlow 60D Air Compressor—a game-changer for your air inflation needs. Designed for durability, efficiency, and high performance, the HyperFlow 60D is built to handle even the toughest challenges. Here's why this powerhouse should be your go-to air compressor.
Purchase on Wolfbox site!
Purchase on Amazon!
Why Choose Wolfbox HyperFloew 60D Air Compressor?
  • 100% Duty Cycle: Can operate continuously for 60+ minutes under full load in 25℃ environments without stopping.
  • 40℃ High Heat Resistance: Performs exceptionally even in hot climates, working non-stop for 40 minutes.
  • Innovative Cooling: Dual-side active fan intake with an open heat dissipation design keeps the system cool under pressure.
  • Extreme Durability: Built for continuous high-load operations, with a core life of up to 80–100 hours.
  • High Output Performance: 5 CFM @ 40 PSI, ensuring quick and powerful inflation.
  • Perfect for Large Tires: Designed for 35–40” tires—inflate a 37-inch off-road tire from 10–40 PSI in just 3 minutes!
  • Auto Shut-Off: Set your desired tire pressure and let the compressor do the rest. It stops automatically with only ±2 PSI variance.
  • Multi-Wheel Inflation (Optional Accessory): With a high-pressure air source splitting into four independent airways controlled by solenoid valves, you can perform single-wheel, multi-wheel, or four-wheel simultaneous inflation. (Requires additional 4-Tire Inflation & Deflation System.)
Performance at Its Peak:
  • 120L/min flow rate at 40 PSI, ideal for fast and efficient inflation in every adventure.
Special Launch Discount:
  • Regular Price: $369.99
  • Introductory Price: $329.99 (Limited time only!)
Purchase on Amazon!
Looking for an On-Board Air Compressor?
If you’re into onboard setups, check out the Wolfbox HyperFlow X for the ultimate convenience.
Don’t miss out on this incredible deal—gear up with the Wolfbox HyperFlow 60D and conquer the trails without worry!
Available Now: Get yours today and experience inflation like never before!
Purchase on Amazon!
That looks awesome!! I have no use for carrying around that much air supply but that looks and sounds great.
And I just ordered the air duster thanks for gift card. Don't think I need one of these.:clap:
John E Davies
Spokane WA USA
Retired aircraft tech
FYI using a single hose for a single tire is not recommended with any high output compressor, it causes a LOT of heat in the cylinder heads and hoses...... it is best to use a multi hose manifold. If you are blowing dust off stuff, it does not matter.
Where can that be ordered? Cost? I did not see it being available on the web page.
EDIT: found this, do you have an ETA?
"Wolfbox will be releasing a separate four-tire inflation and deflation kit to supplement the HyperFlow 60D at a later date. "
https://www.prnewswire.com/news-rel...inutes-of-continuous-inflation-302800368.html
This one works extremely well:
MORRflate Quad 4 Tire Inflation & Deflation System – 800D Braided Hose – Fits Up to 125" Wheelbase – Manifold, Digital Gauge & Storage Bag Included (Hose Kit Only, No Compressor)
John Davies
Spokane WA USA
Wolfbox
Wolfbox
Florent
CA
Ford Ranger
Thanks for asking, dear friend. We're improving the kit now, and should be available in two months.
FairOaksRaptor
Sonny
Fair Oaks, CA
Anyone try these wolfbox? I have a Milwaukee cordless, and looking to upgrade to an ARB onboard but just seen these ones. Anyone have any real world experience with these?
Wolfbox
Wolfbox
Florent
CA
Ford Ranger
