Adding Adaptive Cruise Control (ACC)
Rangeruser
North Carolina
Has anyone had any luck with adding ACC after purchase? I've seen some threads on the Maverick and F-150 forums about it. Given that the new Ranger shares a lot of F-150 modules, I would hope that the programming values would be similar. For reference, I checked out a few parts that were listed as compatible with the Ranger. I found a Lariat vin that I was thinking of using in conjunction with the Motorcraft Service Manuals to verify the parts numbers.
https://www.f150lightningforum.com/...keep-alert-to-2022-f-150-lightning-xlt.14870/
https://www.mavericktruckclub.com/f...averick-hybrid-xlt-with-luxury-package.14586/
distance SensorML3Z9E731E
BracketN1WZ14C022G
Parking sensor wireN1WZ15K867AS (two harnesses)
SwitchN1WZ9C888C
BoltW505255S450L
Rangeruser
North Carolina
So this looks like it might be a bit more difficult for us. I'm not entirely certain as to their functional differences, but there's a few different models of IPMA for the new Ranger. The biggest difference is that non Technology Package ones are marked as Collision Mitigation System N1WZ14G647BT vs Collision Mitigation System #2 N1WZ14G647BM. Both in the Ford parts store mention they do not include "assist" features.
One of the folks got their acc working with their more basic IPMA after swapping with an advanced one, but it's a toss up as to if that will work for here given there is only one CCM module and it specifically mentions being for collision mitigation system #2.
Now, the really crappy part is the the parts other than the ccm are super expensive lol. So it would even be very cost prohibitive to attempt a swap like that guy in the f-150 forums.
Rangeruser
North Carolina
Not to mention that I don't think we can do a PMI on a part not meant for your VIN. I think FDRS checks beforehand to make sure it's right.
Oh well, I'll check back in a year to see if anyone has found out anything more.
friscoKM
texas
XL F150 21
Have you reached out to Jesseinfotainment on the F150gen14 forum? He might be able to help with this project. I am watching this thread cause i'd love to be able to get a base 24 ranger and add ACC and comma AI. It has been great on my XL single F150.
Rangeruser
North Carolina
I did actually. He responded that it probably won't be possible under the new security architecture they use. Based on what I've read that also seems to be the case. Until someone cracks it I think we're stuck with what we got :(.
Ajzride
Alan
Houston
2021 F150 PB 502A
C&A
Jesse was assuming the new Rangers had TRON (canbus encryption). But since we have some 2024 Rangers using the Comma3x, we know they don't have TRON, so this should still be possible. Not sure if 2025 Ranger added TRON or not.
lourenco
2025 Ranger XLT 2.3L RWD
IT
The new 2025 Ford Ranger does have TRON (canbus encryption) , but I succesfully added Adaptive Cruise Control with lane centering along with the steering wheel control and traffic sign display to my 2025 Ford Ranger XLT with the new 2.3L engine.
Forscan Coding:
(Note: I used the F150 Forscan Coding shown below, but I had to make a few small changes that are not shown below. I will update this coding later today - 3/30/2026)
Please backup and save all the coding for the modules below.
SCCM *Only if you swap the left hand steering wheel switch for the one that includes the follow distance change.
724-03-01 04xx xxxx
ABS
760-03-01 *xxx -- (4 to C)
IPC
720-01-01 x*xx xxxx xx-- (C to F)
720-01-02 xxxx *x-- (4 to 8)
720-03-01 x*xx xxxx xx-- (0 to 5)
720-03-02 xx*x xx-- (4 to C)
720-09-01 *xxx xxxx xx-- (A to B)
720-09-01 xxxx xxxx *x-- (1 to 9)
720-09-02 *xxx xx-- (0 to 2 or 1 to 3)
720-10-01 x*xx xxxx xx-- (A to B)
(Note: Missing Speed Limit Sign Coding to Show Speed Limit Sign Graphic on the Gauge Cluster. I will add the coding for this later today 3/30/2026)
BCM
726-16-01 xxxx x*** xx-- (384 to 390)
APIM
7D0-05-01 *xxx xxxx xx-- (0 to 2)
7D0-05-01 xx*x xxxx xx-- (0 to 8)
7D0-09-01 *xxx xxxx xx-- (4 to 6 OR 5 to 7)
7D0-09-01 xxxx *xxx xx-- (2 to 4)
7D0-09-01 xxxx xxxx x*-- (set to B)
7D0-09-02 xxx* xxxx xx-- (4 to E or 5 to F)
7D0-09-02 xxxx x*xx xx-- (4 to 7)
7D0-09-02 xxxx xxxx x*-- (5 to D)
7D0-09-04 xxxx xxxx *x-- (0 to 6)
IPMA
706-01-01 *xxx xxxx xx-- (0 to 8)
706-01-01 xx*x xxxx xx-- (0 to 5)
706-01-01 xxx* xxxx xx-- (0 to 8)
706-01-01 xxxx xxxx x*-- (A to E)
706-02-01 *xxx xxxx xx-- (3 to 7)
706-02-02 x**x xxxx xx--(04 to 05)
706-16-01 *xxx xxxx xx-- (0 to 1)
706-16-01 xxx* xxxx xx-- (9 to B)
IMPORTANT: Disconnect FORScan and turn the truck completely off, then back on. Reconnect FORScan BUT do not use the saved profile. Let it rescan for all modules. The CCM Module will be shown after the full rescan. If you use a saved profile, you will not see the CCM Module.
Connect to the CCM module to program module with your truck's vin number.
** Note: I need to verify the CCM coding below is valid for the Ford Ranger. I only updated the CCM module with my truck's vin number. **
764-01-01 xxxx xxxx xx-- (Not Verified)
764-01-02 xxxx xxxx xx-- (Not Verified)
764-01-03 xxxx xxxx xx-- (Not Verified)
764-01-04 xxxx -- (Not Verified)
PSCM
730-02-02 xxxx **xx xx-- (00 to FF)
730-02-02 xxxx xx** xx-- (00 to FF)
730-02-03 **xx xxxx xx-- (00 to FF)
Once the coding is done, CLEAR ALL DTC, and calibrate the CCM.
Note: The front collision system is disabled until the CCM is calibrated. You will see this error message on your gauge cluster.
CCM Calibration:
In Forscan, go to the wrench icon on the left to get to the service menu and select CCM Calibration. This will require you to drive around for around ~10-15 minutes for the CCM module to calibrate. You will see a message like CCM Requires Alignment on the gauge cluster during the calibration process.
Note: Towards the end of the calibration process, Forscan will stay at 99% Calibration Completed for several minutes, which is no cause for concern.
Once CCM calibration has finished, the front collision system will function along with the adaptive cruise control. If you have not installed the left steering wheel adaptive cruise switch, you have (3 Bar) following distance that you can't adjust.
Parts List:
CCM Distance Sensor - $125 (Used CCM on eBay from a 2023 F150)ML3Z9E731E or Search for ML3T-9G768-AL (Engineering Part Number on Label)
CCM - Connector Pigtail - $12WPT-1198
CCM Bracket - $136.46N1WZ14C022G
CCM Bracket Bolts Left and Right (Pack of 4 - Only need 2) - $10.40W718083S450B
CCM Bracket Bottom Bolt?
CCM Black Plastic Cover - $29.45N1WZ14C022F
CCM Cover Push Pins (Pack of 4 - Only need 2) - $10.40W714415S300
IPMA - Pin Wire Connector (Pack of 5 - Only need 4) - $33.02WT1002
IPMA to CCM Wiring - 4 Conductor Electrical Wire ~18AWG (CCM +, CCM -, CCM CAN Low, CCM CAN High)Amazon
Left Steering Wheel Switch for Adaptive Cruise Control (Optional for adjusting following distance) - $65.00N1WZ9C888D
Mike-R
South Africa
XLT 4x4 2025
Howzit guys,
I've successfully installed and activated Adaptive Cruise Control (ACC) on my 2025 Ranger XLT (South Africa).
Following the guide above, together with information from the F-150 and various DIY forums, and additional details on where and how to wire the ACC module, I managed to get everything working. However, I haven't been able to get Stop & Go or Lane Assist/Lane Centering working.
After some troubleshooting, I discovered that the ABS module fitted to my XLT appears to be different from the units fitted to Wildtrak and Raptor models.
There are several non As-Built functions available on my ABS module that aren't present on the Wildtrak or Raptor variants. One of these allows me to specify whether the vehicle has standard Adaptive Cruise Control or Adaptive Cruise Control with Stop & Go. (I Only have ACC without Stop and Go on my ABS Module) When I enable the Stop & Go feature in the BCM, the ABS module immediately throws a DTC and reports that the config is wrong from the BCM and that the related safety systems are disabled because it doesn't appear to support that configuration.
This makes me think there may be different variants of the ABS module, some with firmware that supports Stop & Go and others without. At the moment, I'm leaning towards this being a firmware or module variant difference rather than just a configuration issue, as the required settings appear to be accepted but the functionality itself is still missing.
The issue is that when the ABS module isn't happy with the configuration, it disables the IPMA Pre-Collision Assist system, which in turn disables ACC completely.
So now I'm trying to figure out whether:
1. There are different ABS module hardware variants between the XLT and the higher-spec Wildtrak/Raptor models (especially in South Africa)
2. The hardware is the same, but different firmware is loaded depending on the vehicle specification.
PS: You can 100% enable ACC with only non as build configs. Just make sure your Forscan version is the latest release.
Ill update when i have more detail on this ABS module.
Cheers.
friscoKM
texas
XL F150 21
Howzit guys,
Cheers.
Did you figure out the issue?
Forscan Coding:
724-03-01 04xx xxxx
ABS
IPC
BCM
APIM
IPMA
PSCM
CCM Calibration:
Parts List:
Does lane centerning and ACC still work for you? any updates to the coding?
