Adding heated Mirrors to XLT
ShadowDragon24
2025 Ranger XLT Fx4
Heavy Equipment Operator
As the title says. I have officially started the process of adding heated mirrors to my xlt. Back in april I popped the door panel above the mirror plug off, and found my xlt is prewired for heated mirrors, turns, and puddle lights.
I ordered the heated glass. and I got the pins for the mirror side of the plug. I'll be updating this thread when I start the swap, and forscan easy programing options to enable(should just be in each door module, ill have to dive back in and look). I'll get a new battery for my infrared instant read thermometer to show it working too(hopefully lol)
This is the wire you need(pin 1) to see if you're prewired for heat, and the WT1013 is the pin you need for the mirror plug to go in pin 1
Its funny, my 2012 escape xlt came standard with heated mirrors, yet my 2025 ranger xlt, it was an option.
Ford Ranger Adding heated Mirrors to XLT Screenshot_20260108_214747_Samsung Internet
Ford Ranger Adding heated Mirrors to XLT Screenshot_20260119_062157_Samsung Internet
Ford Ranger Adding heated Mirrors to XLT Screenshot_20251128_175522_Gallery
Ford Ranger Adding heated Mirrors to XLT 20250525_123722
ryanO
Ryan
2025 RangerXLT
Sales
I ordered the heated glass. and I got the pins for the mirror side of the plug. I'll be updating this thread when I start the swap, and forscan easy programing options to enable(should just be in each door module, ill have to dive back in and look). I'll get a new battery for my instant read thermometer to show it working too(hopefully lol)
So to add puddle lamps would I need all new mirror surrounds?
ShadowDragon24
ShadowDragon24
2025 Ranger XLT Fx4
I say the full assembly, the xlt mirrors dont have the cutouts for the turns, or the puddle. or you could add strips under the door/mirrors, and tap the wire in the door mirror harness. the one circled in red. pin 11(the plug does have the pin locations #'d) you maybe be able to drill the hole in the bottom of the mirror where the puddle light went, and put in a set, then wire them in. the pin for the heated glass, is the same for the turn and puddle lights
you can then use forscan to enable them. and change your zone lighting in the bcm or the apc? from 2 zone(front and back like my xlt) to 4 zone(front, back, and both sides) and i think then each door module
Ford Ranger Adding heated Mirrors to XLT Screenshot_20260215_220942_Samsung Internet
Ford Ranger Adding heated Mirrors to XLT 20260121_201723
Ford Ranger Adding heated Mirrors to XLT 20260121_201703
Ford Ranger Adding heated Mirrors to XLT Screenshot_20260216_174851_Gallery
Kevin
2024 Ford Ranger XLT
Hi! Were you successful in adding the heated mirrors? Also, do you have the part number for the heated glass that you ordered? Thanks.
ShadowDragon24
ShadowDragon24
2025 Ranger XLT Fx4
my cousin called me(works in the parts dept at my dealer)30mins ago, glass is in. I'll be getting off em later this evening. and hopefully next few days get em installed
ShadowDragon24
ShadowDragon24
2025 Ranger XLT Fx4
Awesome, thanks! Can you send the part numbers for the glass when you get the chance?
I will be getting the part numbers for you soon. I have had them installed about 5 days and they work awesome. I need to find some extra pins. For now I just cut and spliced, and made jumpers for the time being.
and when I get time, Ill be updating this post with the temporary wiring, and the walk-through of how to swap em and stuff untill I can get the proper pins to make it easily removable/factory
ShadowDragon24
ShadowDragon24
2025 Ranger XLT Fx4
Amazing work! Very excited to copy you.
here is the part numbers for the heated glass with blind spot. im waiting to do full write up once I get the proper pins. but I can show you my jumper set up later
Ford Ranger Adding heated Mirrors to XLT 20260317_081503
Ford Ranger Adding heated Mirrors to XLT 20260317_081449
ShadowDragon24
ShadowDragon24
2025 Ranger XLT Fx4
so while Im waiting on being free enough from work to go into my dealer with the 2 pins I cut off the truck side to get the proper pin, Ill leave this here I ran the wire I had that was a correct mirror plug pin, this wire is for the puddle lights, I then ran 3 more wires, 1 for the ground, 1 for the mirror heater, and 1 for turn signals. I can use those as the wires inside the mirror, and just tap the pins to them.
Ford Ranger Adding heated Mirrors to XLT 20260225_125247
Ford Ranger Adding heated Mirrors to XLT 20260226_193247
Ford Ranger Adding heated Mirrors to XLT 20260225_125913
Ford Ranger Adding heated Mirrors to XLT 20260225_111121
Ford Ranger Adding heated Mirrors to XLT 20260225_111135
Ford Ranger Adding heated Mirrors to XLT 20260225_111130
Ford Ranger Adding heated Mirrors to XLT 20260225_111359
Ford Ranger Adding heated Mirrors to XLT 20260225_111536
Ford Ranger Adding heated Mirrors to XLT 20260225_112243
Ford Ranger Adding heated Mirrors to XLT 20260225_112249
Ford Ranger Adding heated Mirrors to XLT 20260225_112255
Ford Ranger Adding heated Mirrors to XLT 20260225_112358
BB1959
Bobby
virginia
2025 Ranger XLT
Do you have pictures and or information on how to remove the factory mirror glass from the housings?
ShadowDragon24
ShadowDragon24
2025 Ranger XLT Fx4
2 of the wires I ran, are just dead ended on both ends. the ground and heater I poked out through the rubber next to the plug and depinned the truck, and just spliced into the ground, and the heater wire. then into forscan to enable them. I found in the HVAC module, and each door module.
as for removing the mirror glass. the FSM shoes a slot a flathead fits in. and that is the point of pry on thr mirror glass only. and it doesn't feel good. I had to put more pressure then I wanted to the first time. but was able to pop off the glass.
Ford Ranger Adding heated Mirrors to XLT 20260226_211448
Ford Ranger Adding heated Mirrors to XLT 20260226_211450
Ford Ranger Adding heated Mirrors to XLT 20260226_211428
Ford Ranger Adding heated Mirrors to XLT 20260226_211525
Ford Ranger Adding heated Mirrors to XLT 20260226_211533
Ford Ranger Adding heated Mirrors to XLT 20260226_211549
Ford Ranger Adding heated Mirrors to XLT 20260226_211545
Ford Ranger Adding heated Mirrors to XLT 20260226_212044
Ford Ranger Adding heated Mirrors to XLT 20260226_212036
in hvac heater type has to go to climate control relay to automatically come onnwith the rear defroster
Ford Ranger Adding heated Mirrors to XLT Screenshot_20260216_002136_Gallery
Ford Ranger Adding heated Mirrors to XLT Screenshot_20260216_002151_Gallery
Ford Ranger Adding heated Mirrors to XLT Screenshot_20260216_002155_Gallery
Ford Ranger Adding heated Mirrors to XLT Screenshot_20260216_002200_Gallery
Ford Ranger Adding heated Mirrors to XLT Screenshot_20260216_002220_Gallery
Ford Ranger Adding heated Mirrors to XLT Screenshot_20260216_002203_Gallery
BB1959
Bobby
virginia
2025 Ranger XLT
Do you insert the flat head screwdriver in until it gets to the center of the round plastic mirror mounting plate and center of the glass or just along the edge where the slot is? Twist the screwdriver or pry up on it?
My 2025 XLT has the wires at pin 1 on both sides. The heated mirror part #'s you show in your post do fit an XLT housing with folding mirrors, Blis and cameras?
Just a recap, I will need to swap out the mirror glass and connect wiring from them to pin 1 (power) and Pin 8 (ground). Will I need special connectors for the two terminals on the back of the glass? Then reconnect Blis and enable the heated mirrors and climate relay function in Forscan?
Thanks!!!!!!!
ShadowDragon24
ShadowDragon24
2025 Ranger XLT Fx4
So Pin 1(mirror heat) and pin 10(turn) on the mirror side take a WT1012 pin each, Pin 8(ground) and pin 11(puddle) take a WT1013 pin each. The mirror glass takes 2 WT(waiting on cousin in parts dept to look up my bill and let me know what 4 pins he got for the glass, will update when he get back to me) I did have to take a set of needle nose pliers and squat the mirror pins slightly to make sure there was no chance of them falling off too, they were a lil loose for my liking
This will allow you to add heated mirror glass, puddle lights, and if you want to drill some holes and add some 3/4 button leds or even a side shotting led strip behind the mirror on the edge of the housing for turn signals. if you only want heated mirrors, pin 1 and 8, if you only wanted puddles pin 11 and 8, only want turns, pin 10 and 8. you have options.
I got the pins, picked them up today, suppose to rain later this evening, and tomorrow, and possible saturday. but I will update this post once I get them installed.
next payday I will pick up a set of amazon puddle lights so I can get my wiring for them done, and hole cut in the underside. or I might just wait and get a half decent pair from form lighting if they got the new style out. or I might just add a new Diode Dynamics dual revolution rock light under the mirror, and have the white as the puddle, and the amber as the turn. only thing then is I probably have to get their PWM modules to then dim the rock lights output for the lights. lol
It just goes to show options. I see other places are starting to make 3d printed under mirror mounts for the dd rock lights, maybe we can get them to do the rangers too.
ShadowDragon24
ShadowDragon24
2025 Ranger XLT Fx4
Finally got around to removing my jumper wires and getting the pins in the plug, now its easily removable just like factory. Still trying to track down my recipt with the 4 pins for the mirror tabs. but the information thus far will get you to the pins on the glass if you have connectors of your own to fit.
Next for me is to get some Diode Dynamics dual function rock lights for the puddle/turn signal lights.
this is how I made my jumpers, I just cut off the pins and butt spliced the wires in, and these are the female pins I used on the mirror glass it self. and the part number Im trying to find for the 4 of these, the head is slightly larger then the pins on the glass, all I did was squat them slightly with pliers, and ran heatshrink up to the very edge to protect them.
I did oversize the wiring inside the mirrors, as thats what I had. once I go to put in the puddle/turn lights, Ill be redoing the wiring to less bulky sizes and length.
Ford Ranger Adding heated Mirrors to XLT 20260529_123520
Ford Ranger Adding heated Mirrors to XLT 20260529_132702
Ford Ranger Adding heated Mirrors to XLT 20260507_120611
Ford Ranger Adding heated Mirrors to XLT 1778179776603_11872521075051
Ford Ranger Adding heated Mirrors to XLT 20260529_113134
Ford Ranger Adding heated Mirrors to XLT 20260529_130801
