Amp Power Steps
Hinkel
Chris
St Croix
2024 ranger raptor
Has anyone figured out how to make the Amp Research Power steps work on the RR? I tried the obvious set up and they went up and stayed up...
81stfacp
CTS
Trident installed mine. Since you are not in the same area and not a competition, they may be kind enough to give you some tips. A long shot, but worth a try.
https://www.tridentatx.com/
Hinkel
Chris
St Croix
2024 ranger raptor
Ohh thatill help for sure. Thanks for the lead!
BDMEM
Joe
Pickwick/Mississippi
2024 Ranger Raptor/ 2025 Explorer ST
Fedex/Retired Mx
Hello All : For what its worth AMP will not help you. For my Raptor did my homework 1) F=150 Raptor has two motors an can be wired into eng. bay plus must cut boards. 2) Bronco Raptor has Four Motors an no need to cut boards.But will need to pull power from OBii Connector only .
Also beware of fast hard closing, tryng to work on this problem right now. A person on this web site may have a fix looking into rubber plug for mine.
Good Luck
Hinkel
Chris
St Croix
2024 ranger raptor
So Trident let me know they just wired them up to the dome light, she didnt have much info but i am assuming that would mean that both sets of steps (drvr and pass) come down when any door is opened which is no big deal. But if anyone else has these hooked up and working, i am still interested in hearing how and where the signal is tapped in from under the dash(where do you hook up the blue and white wires from the AMP OBD plug) Thankx for everyones help Chris
BrrRaptor
Scott
Raleigh Nc.
Some vehicles use a switched ground instead of 12v. Do you know which the Ranger is? Might be why yours only went up?
