Audio Off
SubaruRaptor
Jory
North
So went to the store this morning and all was fine. Got back in my truck and there was no audio. There is no voice commands either. The radio just says "Audio Off". Tried resetting sync by holding volume down and fast forward but still the same. Looking online it seems this is a long going problem with Ford Sync and its pull a fuse or pull the battery cable.
Does anyone know which fuse to pull or had the same issue? Im going to pull the battery cable later today but thought id ask.
jrRaptor
Maize, KS
That's a new one. Maybe try the ACM fuse? Fuse #32 in the BCM fuse box. Looks like a yellow 20A fuse.
Ford Motor Company
Official Ford Account
Ford
Dearborn, MI
Ford Ranger
Hey there! I can take a closer look into your audio concerns should you need further assistance. Just shoot us a direct message with your VIN and dealer name/location, and I'll get right on it. To send a direct message, just click on our username and select "Send Direct Message". Thank you!
SubaruRaptor
Jory
North
Just to round this thread off. A disconnect of the battery terminal was able to resolve the issue.
For others if they have this issue. The Negative terminal is secured with a 10mm bolt. Youll need a deep well socket or a short extension to make life easier. Pop off the terminal for a few minutes and reconnect and retighten. When the truck turns back on, it will initially say Audio Off, then load the radio.
John B
Kansas City, Missouri
2024 ford ranger raptor
retired engineer
I've just started keeping a 10mm nut driver in that upper glovebox. Useful for multiple issues...lol
jrRaptor
Maize, KS
This is the way
