Audio upgrade for 2025.25 Wildtrak - Wiring diagrams / pinouts?
mynameisplayer
Australia
2025 Ranger Wildtrak
Have done a sub upgrade, but using the existing sub output to drive an amp you are met with a bass cut from 14 above volume. It's also not full range, as in there's a low frequency cutoff. I've read that tapping into the door speakers gives a full-range with no cut. Other images of pin-outs (FB etc) show for Bronco or F150. Any pinouts for .Au cars?
This is the closest I can find, but taping into wh/wh-br has no audio.
https://www.ranger6g.com/forum/threads/need-wiring-help.21726/
Sharpix
Tony
MX
Tinkerer Fixer
Forscan and disable bass cutoff. search.
Pinout just take off door card and watch wire colors. Take off the pillar b down liner and your speaker cables will be there for the Line Output Converter.
I. have a wildtrak too. mexico
mynameisplayer
Australia
Awesome - thanks. I have seen threads that say in door wire colors are different to amp/loom colors. Our cars are made in Thailand, but only info I can see id US cars.
Sharpix
Tony
MX
Tinkerer Fixer
Mine is 703P made in south africa.
find the Forscan rear audio bass cutoff culprit, modify it.
Take off any rear door card, watch wire. colors, the take off pillar b lower cover and if the cable colors are the same, tap from them. They should be FULL RANGE after forscan.
mynameisplayer
Australia
Do we know if the Forscan bass cutoff is just for doors, or the sub? And is it just the Vol @ 14, or is it low end roll-off?
Sharpix
Tony
MX
Tinkerer Fixer
its low end roll off, only rear speakers. exactly where you might take the signal for the high to line converter.
