Bead lock wheels and tire pressures - how to check?
BlancoRaptor
Warren
Arizona
Whats the easiest way of checking and filling tires with Bead lock wheels?
Valve stems are recessed and hard to get at??!!
stuartmunto
Stuart
Perth, Western Australia
2023 Ford Ranger Raptor
Valve extenders?
The valves are purposely recessed so they aren’t damaged by obstacles when tyre pressures are really low - you could say it’s a ā€˜feature’ of the beadlock wheels really
BlancoRaptor
BlancoRaptor
Warren
Arizona
Any recommendations for extenders to fit those wheels and tires?
stuartmunto
Stuart
Just get any basic valve extender off amazon - doesn't need to be anything special, you just use them when filling or checking air pressures so they don't need to be anything specific
https://www.amazon.com/s?k=tire+valve+exender&crid=3V2TIVVTEZ2GO&sprefix=tire+valve+extend,aps,446
something like these might be easier as you'll have more to grip on when screwing onto the valve:
https://www.amazon.com/Extension-Ex...909&sprefix=tire+valve+extend,aps,446&sr=8-13
BlancoRaptor
BlancoRaptor
Warren
Arizona
Hi StuartMunto
I like those $5 tire valve extenders.
Should do the trick for checking and filling tires. Would remove them for driving I guess?!
Golf4fun60
Seattle, Wa
Hi StuartMunto
I put a set on 6 months ago and left them on. They are barely flush with the trim ring and make access to check and fill much easier. I haven’t seen any noticeable leakage. I’ll definitely be getting longer valve stems when I get new tires.
Dutch
The land of the wind chill factor
Are the stems part of the TPI system? If they are separate - that would be great!
Golf4fun60
Seattle, Wa
Leaving a party at 1am to find a flat tire the night after I installed those impressed me.
That item came with five extensions. I found one with a slow leak - but the spare was fine. Six months and haven’t had to add air once.
