Bigger tires no lift no rub. Thoughts.
danmoochie
dan
florida
retired Sales manager
It this the largest tire upgrade on the standard XLT FX4 and OEM rim without lifting and no chance of rubbing? I want higher and wider. Thoughts.
Ford Ranger Bigger tires no lift no rub. Thoughts. PXL_20250407_220643528
Fix4Dirt
SLO County, CA
Height wise, with the Dobs lift on this one, a 33 would probably scrub at lock. So my guess is a 32.6 would also scrub, especially with no front level. But that's just my assumption, and to assume is to make an ass out of you and me haha. (Ass u me)
danmoochie
dan
florida
That's what I'm trying to figure out. Maybe 32s are the biggest then? I think the width will be fine?
Fix4Dirt
SLO County, CA
I think width should be OK. I think at lock stock I had a tiny bit of wiggle room still, so I think width is OK. Height wise is where I dont know, since a true 33 scrubs without new offset/spacers with the Dobs level (1.5"). It seems to me with spacers though a 33 would fit now.
bulldog36526
Dan
Daphne,al
2024 Ranger XLT FX4 2.3L
I'm also looking to put larger rims and tires on mine without putting a lift on it. I don't think a 32" diameter tire x 10.6" wide would be a problem .
danmoochie
dan
florida
But I'm not changing the wheels. I like the OEM XLT FX4 wheels. No lift. Just want taller and wider stance. Without the worry of rubbing anywhere at any time.
danmoochie
dan
florida
Seems that 255/75/17 would be the biggest, yet trouble free tire size.
That will add height but not width correct? I was hoping for a little of both. 265 only .4 wider and staying 70 is .6 taller.
danmoochie
dan
florida
265/70/17 is 10mm wider, but has a smaller diameter. It is not a full 32” tire.
Do you have that size installed?
danmoochie
dan
florida
No, but I know someone who does.
A comparison of these two sizes:
But stock tire is 255/70/17. Going up to 265/70/17. Your showing wrong OEM stock size on XLT FX4.
danmoochie
dan
florida
I am running 267 70 17 bfg ko3s on my 2024 xlt fx4 with no lift or level. The 255s were horrible.
You mean 26t/70/17 right? Those are the exact tires I want to put in the exact same truck. XLT FX4 2.7. And no rub at all? Can you snap a picture of space between inside tire and closest upper suspension. It would be greatly appreciated. This is my exact idea
danmoochie
dan
florida
there has been no rubbing at all in any situation.
Amazing. You have my exact truck and the tires I want on the same rims. Thank you so much for taking the time to confirm and send photo.
