jacksdad
- Joined
- Apr 4, 2025
- Threads
- 7
- Messages
- 142
- Reaction score
- 142
- Location
- North Central WA
- Vehicle(s)
- 2024 Ranger Raptor
- Thread starter
- #1
DIY Guide: Water & Dust Proofing Bed Rails for Pace Edwards Ultragroove Tonneau
I wanted to prepare my truck bed for a Pace Edwards Ultragroove tonneau cover by sealing up the factory rail caps and stake pockets to reduce dust and water ingress. Here’s the process I used:
Tools & Materials
Step 1 – Remove Tail Lights
Step 4 – Seal Rail Voids
Step 5 – Seal Stake Pockets
Step 6 – Reinstall Components
The sealing job feels solid. Once the tonneau cover is installed, I’ll pressure wash and report back on how effective the sealing is against dust and water intrusion.
Tools & Materials
- Pistol-grip needle nose pliers (jaws taped to protect clips)
- Pry tools and flathead screwdrivers
- Oracal 651 vinyl wrap (cut to size for rails)
- 1” x 1” weatherproof self-expanding foam
- Flex Seal waterproof rubberized tape
- Utility knife/scissors (for cutting foam/vinyl)
- Torx t-30 for tail lights
- Pull tail lights to access the rear rail cap clips using torx t-30 and pry tools.
- Starting from the tailgate toward the cab, work from the underside of the rail.
- Use taped needle nose pliers to squeeze clips and push them above the rail.
- On the fender flare side, create clearance under the cap, then use a pry tool to pop outer clips above the rail.
- The toughest clips are at the cab side of the bed. A combo of pry tools and flatheads helped work those free.
- With the rail caps free, cut Oracal 651 vinyl to size.
- Wrap the top surface of the rails from cab to tailgate for extra protection and a clean surface.
- Apply 1” x 1” expanding weatherproof foam along the rails.
- Cut an “X” into the rectangular voids for clip entry.
- Pay attention to orientation so it expands to block voids and seal openings inside the bed walls
- On the underside of the rail caps, cover stake pocket holes with Flex Seal tape.
- This prevents moisture and dust from entering through the open pockets.
- Press rail caps back into place.
- Reinstall tail lights.
- Check that rail caps now fit snug and secure.
