Ford App: Tire Pressure Follows BCM setting
CaptAngry
Denver, CO
2026 RRaptor
Space Engineer
I was playing around with FORScan settings to lower the TPM Placard values for the TPMS. Essentially, 39 psi on the Raptor is too high so I wanted to set it closer to the "chalk test" 36 psi. I know the rear is really closer to 34 unloaded but for now am keeping it 36/36 for simplicity.
Anyway... I set both the front and rear as follows:
BdyCM 726 TPM - Placard Pressure Front, psi 36 726-10-01​
BdyCM 726 TPM - Placard Pressure Rear, psi 36 726-10-01​
What I wasn't expecting is that the Ford App optimal pressures also followed that setting.
Ford Ranger Ford App: Tire Pressure Follows BCM setting rraptor_ford_app_pressur
Maybe I'm the last to the party. Or now you know.
Would it be too much to ask you to post some detailed instructions on how you changed it on Forscan? I recently went with the GOAT 2"/1" strut spacers and put on some Mickey Thompson Baja Boss 315/70/R17's. I did the ride height recalibration myself but the new issue is that since the new tires are E rated, I need to run them at a MUCH lower pressure (30psi/27psi) to prevent them from crowning and to get them to behave properly on road. So now my truck is yelling at me that my tire pressure is too low.
UPDATE: Never mind I figured it out. Thanks.
CaptAngry
CaptAngry
Denver, CO
2026 RRaptor
Space Engineer
It was as simple as going into the BdyCM menu (non-as built) and setting the two Placard Pressure entries to what I wanted. Write the module and reset it. Simple as that.
I don't have screenshots but I found a similar one online
Ford Ranger Ford App: Tire Pressure Follows BCM setting forscan_bdycm_tpm_placard
I figured it out after all thank you.
sulnw
suthep
Thailand
Ranger Stormtrak
construct
