Crapblaster
I got my bedrug and X4s cover installed. Both fit very well. The bedrug took the longest. I will have to look at the bed lights when I install the J-Braces. They had something holding them on the outside after taking the two screws out.
Ford Ranger Got my Bedrug Installed bedrug2
Ford Ranger Got my Bedrug Installed 43427-bf6dd9b0ad2368b9d8dcb4037a00117f
gstahl
Geoff
Denver, CO
24 Ranger Raptor, 20 F-150 Raptor, 23 Taycan GTS
Software
Looks great. Was it all straightforward?
Crapblaster
Crapblaster
pretty straight forward. I cut slits for the bed tie downs instead of taking them off and bolting them over the bedrug. Stiil have to work on the bedlights. The cover was very easy to install and I think it will work with the accessory rail setup.
Skitrem47
Albany, NY
Toyota 4 Runner TRD Pro
Teacher
What are you doing for your undercoating Krown? This will be the first vehicle I have ever done undercoating on. I do not want to go the Ziebart route… that makes me nervous.
nswilliams
Norman
2024 Ranger Lariat 4/19/24
Senior Research Engineer
I have exactly same bedding and x4 cover. I added frame around LED opening using cheap wallpaper frame from Walmart. Also it requires more effort to close gate due to fabric between bed and gate.
Ford Ranger Got my Bedrug Installed IMG_0835
Ford Ranger Got my Bedrug Installed IMG_0838
Ford Ranger Got my Bedrug Installed IMG_0836
olefordguy
Craig
Alabama
I’ve had the bed rug in my current truck few years, they are awesome, makes it easy on the knees
Minnesota
2024 ranger raptor, Honda passport
I must say…that looks darn awesome…..great job. I was Going to wait to order one for the green machine to be certain of fit, I need to wait no more.
Haole
Lexington, KY
2024 Ford Ranger XLT
Teacher
I also had trouble getting the tie-downs out without ruining the screw heads so I just cut slits for those. For the cargo lights, I got a small sheet of 16 gauge metal from Home Depot and made two cover plates instead of trying to get to the backside to find the release clips others mentioned. Just used a jigsaw, dremel, drill, and paint. Used the same screws.
Ford Ranger Got my Bedrug Installed IMG_3127
Ford Ranger Got my Bedrug Installed IMG_3128
Evilrider
Lloyd
Chester Va
2024 ranger raptor 2022 Explorer King Ranch
looks real good. had Bed Rug on my last 2 F150 never had a complante
Rhite95
Rick
N/A
Looking good!!
Rapture2423
Midwest
Silly question but would a bedbug fit on top of spray in liner?
KayaPayaPigDog
Kyle
www.youtube.com
US Navy
The clearance is already pretty tight for a sheet of plywood between the wheel wells… has anyone tried fitting plywood or drywall in with the bed rug? Stock is 48.2 inches so we have less than 1/4” to play with and I wasn’t sure if the bed rug on both sides would be more than that.
JimmyGator
Phoenix, AZ
2024 Ranger Raptor, 2022 Bronco Raptor
@Crapblaster This looks great. I have one of these on my F250 and it's awesome. Want to do it to the RR but when I went to the BedRug site, they show that it is not compatible for RR, just non-Raptor 2024 Ranger. Which model of bedrug did you get for yours? It looks like it fit so well that likely the standard Ranger BedRug has simply not been validated for RR. Does this sound correct to you? Thanks!!!
