Help Needed - New Tail Light Assembly Triggering 2X Blinker Speed
daytoncarter
Dayton
Thanks for the insight. Very helpful.
Thanks for the sarcasm. Your turn signals are not serviceable it's all built in LEDs. There's no insight to give unless you want me to google the part numbers for you to replace the entire headlight/tail light yourself.
The hyperblink is a turn signal out indicator, or at least a fault. It should hyperblink on the side with the issue. Then you can isolate front or rear visually or using an advanced code reader like Forscan.
But there's no serviceable parts.
LokenRanch
Ken
Bozeman, MT
Ranger Raptor White, AMG-GTS, X5
You are most likely correct although it can be a canbus issue as the dealer was able to see the error when logging in. My question was to see the OP's outcome. We all know there is a warranty included with these trucks. I prefer to see the outcome of another member prior making an appointment with my dealer and the down time.
