Key Fob not working and heat not working
kjohnson3636
karen
Monroe
2024 Ford Ranger XLT
First of all, I thought I would love this truck!
So far I have had more problems than expected.
The key fob would not unlock or lock the vehicle or start it remotely. I had to use the FordPass app to start the vehicle.
The cab heat does not work like it should seems I can put it on 80+ degrees and it’s lukewarm. When I put it on 75 it’s like the air conditioner is running.
This will be my seventh time in for repairs since I bought the vehicle around Christmas.
Any others having issues like this?
skinnyjimmy
Sorry to hear you're having these issues! I only have 1,200 miles on mine and don't have any issues. I will say that at around 68ÂşF I can feel the heat kick into the cabin and it's stranger than from my 2013 Ford Focus. I wish it was more gradual. My body always overheats though so I keep my car at 65ÂşF for A/C or 75ÂşF for heat.
dang, that is horrible that your truck seems to be a lemon. mine is trouble free also, which i am thankful for because my previous truck was in the shop alot, too.
i hope you get it fixed and its trouble free from then onwards
ChronciallyChronic
Central Florida
2024 Ford Ranger Lariat
Have you had multiple repair attempts for the same issue(s)? If so, sounds like it's past time to Lemon Law the truck.
Did everything work properly at delivery or did you see issues then?
Sounds like the key fob lost the program match to the truck. Have you gone through the process to re-program the fob?
kjohnson3636
karen
Monroe
Thanks for your feedback. Took into dealer and tech wrote NPF, I’m still wanting to re-program key fob, although it seems to be working.
regarding heat and air issues, tech sat in truck with me and said “sorry but this is how it is,” but acknowledged that passenger and drivers heat and cool temps do not change when on separate settings! NPF! I’m living with it for now. Tech is contacting engineer.
ChronciallyChronic
Central Florida
Sorry, repair tech, but this IS NOT how it is. Sounds like you should take it to a different Ford shop, a shop with techs that know what they are talking about. I don't know about anyone else, but I can confirm the heating and cooling in the truck does actually work, the air temp does actually change when you adjust the temp setting, heat blows warm to hot air, A/C blows cool to cold air. For that tech to essentially tell you everything is working as intended is absurd.
Regarding the key fob, you can reprogram that yourself. There's a spot in the center console to place the fob for the reprogram, review the owners manual for the steps to do this.
spranger
stephen
cambridge
2024 frod ranger xlt
I agree with you about the heat; it is nothing like my F-350 or Edge your feet do get cold it's not as powerful as the older fords I have owned, I have heard people with the Broncos have said the something not as powerful or much heat to the floor, both of my other fords would roast you out if you didn't turn it down. I live in Boston & it gets cold, but the ranger doesn't even come close to keeping your feet warm even just the dash & floor aren't that great ether, defrost works without any problems
