Mattsraptor 2025
- Thread starter
- #1
Couple of questions re the V6 RR.
1) Keyless Entry: If Keyless entry is switched off from the infotainment screen, will the keys continue to transmit, or are they disabled through the screen at the same time?
I suppose this is more relevant with the new motion sensing keys, will they remain permanently dormant if keyless entry is deactivated?
2) Default settings: If you set up your personal mode preferences, i.e. steering, exhaust, suspension etc. and then switch off the engine, will those settings remain when starting up again, or they have set up again, i.e. are the last settings saved? I know they can be saved in “R” mode, but will the system revert back to “R” mode by default if that was the last setting used?
Or, in order to retain the last setup, changes have to be made through Forscan?
Cheers.
Cheers.
