- Joined
- Feb 27, 2025
- Threads
- 38
- Messages
- 1,138
- Reaction score
- 1,724
- Location
- United States
- Vehicle(s)
- 2024 Ranger Raptor
- Occupation
- Electrical Engineer
- Thread starter
- #16
XTM's in 285/70R17 are 53 lbs per tire vs. the OE Ford spec. BFG KO3 at 56 lbs per tire. So, your dropping 12 lbs in tire and another ~ 12 lbs in wheel mass.
I came over from Ford Beadlocks, which were insanely heavy at 36 lbs per wheel! So, stock setup with OE beadlocks = 56 lb tire + 36 lb wheel = 92 lbs.
My final set up will be Method 705s + Pirelli XTM = 53 lb tire + 25.2 lb wheel = 78.2 lbs.
That's just per one wheel and there are obviously 4 wheels (spare tire too, but it's not rotating mass so while if you also do the spare, which plan to do, it won't have any noticeable impact).
Total Weight Difference: (92 - 78.2) * 4 = 55.2 lbs less rotating mass! That is HUGE in terms of WHP. Yes, the engine makes the same power, but less power is wasted trying to spin up large mass (think of swinging a weight on a rope around in a circle, heavier weights are harder to get going), so, more of the available power goes to the rear wheels to actually move the entire vehicle.
If you put a truck or car up on a dyno meter and test with heavier and lighter wheels, you will see differences in measured RWHP (rear wheel horsepower), because with the lighter tires and wheels, you're getting more of the available power to moving the truck, less if being wasted just spinning up the mass.
On top of that the entire truck weighs less too, so the total difference in mass for me (steel spare wheel weighs about the same as the OE beadlocks) = (92 - 78.2) * 5 = 69 lbs lighter truck.
That means you add weight for other gains without increase the total weight of the truck aka use the weight more efficiently, like a heavier higher performance inter cooler, rock sliders etc. I look at the RR more from a performance car perspective, if I add weight in one location, it is ideal to remove it from another location IF possible and not affecting reliability.
I think the Method 705 + Pirelli XTM AT 285/70R17 is the perfect combination for Road / Rally Truck. It's not a "big tire rock crawling" setup, it is more of a high performane race truck setup tailored for higher speeds and better handling, braking and acceleration. It enhances steering precision and also performance on a prepped track, dirt roads, gravel roads, sand dunes etc. anywhere that is high speed.
