Ranger 2024-2025 Modular Bedliner Review
RangerStranger
2025 Ford Ranger | 2.3L Ecoboost
Product Number: R1WZ2600038A
I want to give a heads up to the Ford Ranger community if you’re thinking about the OEM bedliner. Short answer: extremely disappointed. Below is my review, if Ford even post it on their page.
I bought this for my parents’ truck thinking it would be a nice add-on. Would rate it negative if I could for wasting money and my time. For the price, you expect pre-cut out and trimmed panels. NOPE! It was very clear during manufacturing from Ford, nothing was holding the panels down and they missed ALL the cut-out lines and the panels moved during the trimming process. How do I know? You can clearly see on the backside where the edge border for where the cut was supposed to be. ALL, and I mean ALL, edges have a S-shape cut and extremely jagged. Example, my tailgate panel, one end was trimmed so much compared to the other that a large portion of my tailgate is still exposed. Many plastics flash (overhanging plastic). Also, you, yes the customer, after spending this kind of money for plastic, still have to make the cut-outs for the power plug panels on the left side bed wall. Each hole was mislocated, each slot had an irregular shape. Why was each hole so oversized, there is no bearing against the bolt, they rely on the hardware with a large washer. So in other words, the panels are held together solely by clamping, which is eventually going to get loose and thus having all your panels just jiggling around the bolt holes. Don’t say add more torque to tighten it, each bolt can only take so much before stripping the threads. Oh, and you have to remove the tie-down bolts, which Ford literally used red Loctite for the entire shank of the bolt and guessing about 150 ft-lbs to remove. I am not exaggerating that FORD literally soaked each tie-down bolt with red Loctite. I stripped 3 bolts heads and scratched up paint bed just trying to remove it. Now I am stuck with 3 striped bolts so I can’t even install the side panels, scratched up paint which will cost me a lot of money and time to fix correctly just to install a poorly made soft plastic cover. The only shot you have a removing the tie-down bolts is using a harden steel T40 Torx with a breaker bar and SLOWLY loosen it with a heat gun. You may have to tighten and loosen a bunch of times. The irony, this was supposed to protect the paint. Packaging came rolled up like a burrito so all your panels are deformed too. It’s very clear they don’t care about the product. They proudly say it made in the USA, but would have rather have it made overseas since the quality would have been better. Cherry on top, it’s non-refundable. I felt cheated of the product and from Ford. Please go elsewhere for a bedliner, it’s an unacceptable product for the money.
Ford Ranger Ranger 2024-2025 Modular Bedliner Review Bedliner 1
Ford Ranger Ranger 2024-2025 Modular Bedliner Review bedliner 2
Einhander
Cary
Los Angeles
2022 Ford Bronco Wildtrak
Special Effects Technician
Sadly I had pretty much all the same issues you had. Not a tremendous product. Especially for the price
gtistiffler
Keith
Panama City, FL
2024 Ranger XL 4wd
Technician
I like mine actually. Took my time with the bolts with an extended handle ratchet and MAC torx bit and was able to not strip any. I didn’t have to worry with the cut outs as I have an XL.
Truckin
24 Ranger
Must be a lemon. Mine was ok. Far as bolting to the truck mine had 2, maybe 4(I forget) the remainder is held in place by the liner. A tight fit is why it works.
install video online shows about heating the bolts (yep, should have stated in the directions)
I agree directions mostly suck but have a buddy who is a technical writer and he says most writers don’t know chit of what they are writing and most never see the products. Just specs on how it should work
RichD
Rich
Washington state
There are several tip and threads about the modular bedliner. The only trimming I had to do was around the rear outlets. Took my time and used the tips here, including getting the correct Torx bit for the tie downs. Mine fit perfectly.
i was wondering if it would be screwed up since they are rolled up and put in the box. i saw someone selling theirs for super cheap because it came with their truck (in the box still) and they had their bed sprayed instead. i was thinking of getting it for my son but maybe not, now
Fix4Dirt
SLO County, CA
Interesting, mine was fine. It fit fine. It does make sense the power points arent cut out, since some trucks didn't come with them. Do you have pictures of it, I'm curious now. Not unless this is a newer issue, I got mine maybe 6mo ago.
RichD
Rich
Washington state
I love mine. If I could get it super cheap, even better! Just do a search in this forum about the modular bedliner, most are happy with theirs.
