Rear Shock Torque Specs 2025 XLT
BB1959
Bobby
virginia
2025 Ranger XLT
I ordered a set of Bilstein 4600's for my Ranger. Does anyone know what the torque specs are for the mounting bolts?
@BB1959 did you find the answer yet? My 4600's just arrived (well, they arrived a few days ago but the tax man gave me detention)
Edit: I just found the repair manual on usb drive I’d bought when I bought my paper copy of the owners manual; I’d misplaced the thumb drive and forgot about it until today. Anyway, that manual indicates 59 lb. Ft. (80 Nm) for both upper and lower bolts and nuts.
Ford Ranger Rear Shock Torque Specs 2025 XLT IMG_9140
BB1959
Bobby
virginia
2025 Ranger XLT
Thanks, I didn’t get an answer but torqued them to 60 ft/lbs. that was a lucky guess! 😬
Max 57
matt
willington ct
24 ranger 2.7 lariat
were they a hassle to change with the wheel liners in place or did you remove them. and did they improve the ride.
BB1959
Bobby
virginia
2025 Ranger XLT
They were not too bad to change. I did not have to remove the liners, I had to hold them out of the way of the mounting bolts with a small pry bar. The ride seems better, not as harsh as the OEM shocks and less body sway.
Max 57
matt
willington ct
thanks, just got my 4600s will be installing this weekend.
I'd say they were easy to change. I'd suggest removing the wheel liners to make the install easier as that would make getting a torque wrench in place a lot easier, though it's doable with the liners in place. If you remove the liners it's a great opportunity to spray a lanolin-based undercoating (wool wax, surface shield, or fluid film) everywhere.
I noticed a clear improvement with the shocks. They really tamed the damping and made the ride on rough roads feel "softer" even though the springs are unchanged.
