Reverse Light Wire
Sauce
Northeast
2025 Ranger XLT FX4
I want to add aux reverse lights with a relay triggered by the oem reverse light signal. It doesn’t appear that feature is specifically fused (tell me if I’m wrong) so since I can’t fusetap the relay im planning to tap the wire directly. Does anyone know the wire color for the reverse light? I should have gotten it when I paid for 24 hour access to the service manuals but I didn’t ?
Also, anyone know if there’s enough fuse capacity to tap a couple amps power from that wire or would I be better off just wiring to the relay and using aux power?
assuming I only need to tap one side.
ntbruncie
Nick
Phoenix Arizona
If you look down by the hitch on the outer side of it you will see a harness you can tap in there. The harness leading up to the tail lights it’s not going to help you, all the wires are black.
Ford Ranger Reverse Light Wire IMG_4037
Sauce
Sauce
Northeast
2025 Ranger XLT FX4
Thanks a lot. Looks like I’ll tap the green / brown wire there.
any idea if it’s fused with enough headroom to tap another 2 amps, or should I just play it safe and tap it to a relay and run power separately?
ntbruncie
Nick
Phoenix Arizona
The harness comes straight from the BCM. I would run a relay and power.
ShadowDragon24
2025 Ranger XLT Fx4
Heavy Equipment Operator
Diode Dynamics C1R pods. using the 2 output 7pin trailer harness I did have to modify the harness. the new universal one they came out with a few years that you could tie one wire into the brake to stop the trailer light error wouldnt work. when ever my I would turn on a turn signal I get that side trailer bulb error because the c1r wasnt flashing, except when my foot was on the brake. the error go away.
so I was getting a cap, and as per the ford body builder guide, I tapped the 3rd brake wire at the bcm, and ran wire to back, tried the brake wire in the plug the provided, still didnt work.
I know these 3rd brake modules for trailers take signal from both turn/brake on a trailer. so I cut the other side brake/turn signal, and attached both wires to the brake wire I ran.
Now the trailer plug powers the marker lights, and the reverse, and the bcm 3rd brake circuit powers the led in the 3rd brake I added. the c1r's, and the cap.
If you however put too much current on the 3rd brake circuit for a cap, etc, you'll need to disable the 3rd brake on the truck. or add in a relay
Ford Ranger Reverse Light Wire 20250822_092217
Ford Ranger Reverse Light Wire 20250822_092233
Ford Ranger Reverse Light Wire Screenshot_20250728_002748_Adobe Acrobat
pezdyspensr
New England
2024 Ranger STX
Pardon me reviving this old thread, but you say you tapped the CHMSL at the BCM.. According to the builders guide, that circuit is already closed in Connector 5. There's also very little additional amperage capacity according to that chart that you could pull before, I assume, getting an error. Did you simply cut and/or splice into the available yellow/gray wire under the dash or is there another way?
ShadowDragon24
2025 Ranger XLT Fx4
I added a very low draw led bulb to my 3rd brake light. this puts it on par with the lariat/raptor amperage available. maybe even higher. I spliced into the yellow wire with grey stripe in pin 13 locstion in connector 5, that feeds the 14g wire I got from the engine bay to the rear. that then splits off to the 3rd brake for the cap, and then to the c1r harness module to power the brake function of the c1r's.
If you're adding extra, or going above the 1.55a of the circuit(if you remove the chmsl brake function) you can always add in a relay off the battery, and use the pin 13 connector 5 wire to trigger the relay. like how ford says to do if you use any of the blunt cut keyed ignition, high beam, or marker light trigger wires under the trm/bcm behind the drivers kick panel.
I got the ignition spliced into my diode dynamics dswitch to automatically turn it on and off. the marker light wire on the night mode wire to turn on my backlighting busbar, and turn on the backlighting of the button panel, my dd elite series fog backlighting, and my grill lights. The high beam wire on one of the dswitch's programable trigger wires, that automatically turn on my lower grill cubes, and on longer drives, Ill add in my ss40 bar. but normally I keep that sepperate from the grill/highbeams.
Ford Ranger Reverse Light Wire Screenshot_20250922_091636_Adobe Acrobat
Ford Ranger Reverse Light Wire Snapchat-979853834
Ford Ranger Reverse Light Wire 20260520_213144
Ford Ranger Reverse Light Wire 20260521_135306
pezdyspensr
New England
2024 Ranger STX
@ShadowDragon24 thanks for the detailed explanation. I've learned a lot on this forum because of folks like you! You say you spliced at the connector. Does that mean you cut the wire and did a 3 way butt connector, or did you do an inline military splice, or are you talking about depinning and repinning the connector?
I love your setup. Noticed you are in Newfoundland. For cutting through some decent fog, I imagine. I'm on the Maine coast and can relate.
My motivation is less glamorous. I have a rare 24 STX with no tow package and no way to tap existing wiring, so I am going the route of the 5G Rangers and tapping off the CHMSL wire to trigger a Red Arc Liberty I purchased (along with their encapsulated diode to avoid backfeed voltage). Also running it off an ignition switched relay so I can avoid being always hot. Just deciding whether to actually cut the CHMSL wire at the BCM or do something more elegant - particularly since I still plan to get a cap with 3rd brake at some point.
ShadowDragon24
2025 Ranger XLT Fx4
I depinned it to give me more room to work. you'll need a 22gauge heatshrink connector. I cut the wire, on the say truck side when I stripped it back I put a 18g wire twisted with the truck side wire, put the crimp on 1 sode, then on the connector side, I just stripped, twisted, and crimped. then I put the pin back in the connector.
if you have a 24, just get the proper harness with the connector for the aftermarket trailer brake plug. (bronco harness for example) they use the same plug. thats what I got for my Hopkins tbc. the hopkins harness for the bronco/expedition, etc.
theres also 3 blunt cut wires next to the trailer module after trailer brake controller plug. a ignition trigger wire, a high beam wire, and a marker light wire. all low draw, so if powering any high draw items, need to add a relay in. I have them hooked to my Diode Dynamics D-Switch, the ignition automatically turns it on and off with the key(besides being able to use it with the truck off) the maker turns on the night mode(backlit buttons) and the backlight busbar for my ss40, fogs, and grill lights, and the high beam wire is on one of the programable trigger wires, and is set to turn my lower grill cubes on with the highbeams. I leave the ss40 off that. unless im going over the highway for a amount of distance. most of my highway driving can be done with the lower grill cubes
Ford Ranger Reverse Light Wire 20250822_150423
Ford Ranger Reverse Light Wire Screenshot_20250910_185236_Adobe Acrobat
pezdyspensr
New England
2024 Ranger STX
Thanks for the reply. Super cool, smart work.
Unfortunately I can’t use the Bronco harness. I don’t have the pre wires and plug in the kick plate area like most do. Specific to the 24 STX with no tow. I bought it in a hurry without realizing how particularly neutered it is. XLTs without tow still got the plug. So I’m stuck doing it the old 5G way. It’s fine. I’ll assess if it’s worth depinning or just cutting and 3 way butt connecting. Thanks for your detailed explanations. I’ll be using the blunt cut green for ignition switching the relay for powering my custom run 12v tow accessory wire. Only nice thing about building my own 7pin setup is I get to upgrade to thicker wiring for charging RV batteries.
Ford Ranger Reverse Light Wire IMG_2714
