Rim size confirmation
Bonder
Manitoba
I was looking at a set of Bronco steel wheels to use for my 24 Lariat fx4 with 18's to use for winter tires. Can anyone confirm if these ones will fit?
This is what they posted for specs
17x7.5 | +55 offset | 6x139.7 bolt pattern
Stamped on every rim:
E 17x7½J -55 DOT TOPY KB3C-1015-BBUSA
I think they would work but wanted to confirm before pulling the trigger
Bonder
Bonder
Manitoba
They will work, offset is a little different but the bolt pattern is the same.
Thanks. I thought our Ranger offset was 55? Would these push them out further or in?
Alaska Steve
Alaska
Standard Lariat wheel:
Wheel: 7.5Jx18 ET55 offset: 53 - 57
Bolt Pattern (PCD): 6x139.7 (6x5.5)
Thread Size: M12 x 1.5
Tire: 255/65R18
They will fit…
Alaska Steve
Alaska
The offset on the stock wheel is +55mm
Arsenall11
Maple Valley Wa
24 Ranger Raptor
Mechanical contractor
The offset on the base wheels is the same, I was thinking of the Sasquatch wheels beads vertexes the Raptor beads.
Bonder
Bonder
Manitoba
Thanks guys, I'll see if I can make the deal to get them
