Running Boards - Your perspective
CaptainMal
Larry
Wimauma, Fl
2026 Ford Ranger
Ford Ranger Running Boards - Your perspective IMG_0093
For me the factory running boards make entrance more difficult. Step on it and then my weak legs cannot slowly lower me into the seat. I sort of fall down as I'm too high off the seat. Best to just stand on the ground, lift up the right leg and slide in. Sure wish there was a grab handle on the drivers' side.
The old wife likes them but her legs are way stronger than mine and she is shorter. Guessing they are somewhat protective for the outer body.
emjay24l
SW-VA
2024 Ranger Lariat FX-4
I had power running boards on a 2010 Mountaineer I drove for around seven years. They are fantastic and ruined me for any other type of running boards. I will be putting a set on my Ranger soon. The current running boards on it are the least useful I have ever used.
kickingaz
Scott
New River, AZ
2026 Ford Ranger Raptor - Carbonized Gray
Self Employed
Those are great unless you off-road your vehicle in rock, like we do. I needed something heavier than the factory running board, a true rock rail that I ordered from Rocky Road Outfitters.
emjay24l
SW-VA
The vast majority of Ranger owners aren't concerned with off roading in these conditions. I will be mostly traveling BLM roads at the worst where a Ranger with an FX4 package will very likely be more than enough capability. Also, the power running boards tuck up higher than fixed boards and overall give more clearance.
Sammy
Stacey
Tennessee
2019 Ranger XLT FX4
If you have a good welder willing to take on the task you can add a 1 or 2 inch extension material on each of the brackets to push out the tube step from the rocker area where i agree that they tuck in to far.
While i didn't do this mod to my current Ranger i did on a previous one.
I actually had my factory running boards shortened in drop-down height, tucking them higher to the body.
Teeze
Central Louisiana
CPA
Can someone with Amp Research measure the height of the step from the ground? My wife has a bad hip the the 11" step height on my Jeep Wranger (also Amp Research) is a bit too much. I'm looking at an XL or XLT with 2WD so just note with your measurement which truck you have. Thanks!
I have them on my Ranger Raptor. When extended they are 11” from the ground. when retracted they are 19” from the ground.
Yes I have these on my R
Yes I have them on my Ranger Raptor. Distance to the ground when retracted is 19”. Distance to the ground when extended is 11”. I’m 6’-1” so i had to pretzel myself in with the original running boards. These are just right…
emjay24l
SW-VA
This is what I really can't stand with the OEM running boards. I am 6' and, like you, I have to crouch in a weird way to squeeze myself into the driver's seat. On top of this, the width of the foot area is way too narrow. Also, getting out of the truck isn't a smooth movement either.
Lastly, with the OEM boards I can't hop into, or out of, the truck easily when not using them. This is because of their width which makes the effective length of my legs 2-3 inches shorter because my leg is at more of an angle entering and existing. I could get in better without running boards but then my wife, grandkids, etc. can't get in at all.
KRC
Karl
2025 Ford Ranger XLT
Diesel Technician
I have personally never been a fan of running boards, but after watching my 7 year old daughter struggle to climb into the truck, I decided some things just aren't always about me.
I ended up going with the Armordillo FX running boards because I like the lights on them. They did take some getting used to for me, but they have grown on me.
Ford Ranger Running Boards - Your perspective 1000024169
Ford Ranger Running Boards - Your perspective 1000023310
KRC
Karl
Diesel Technician
@KRC
I like the lights! Does the dashed effect stay on while driving?
Yes! They act as running/marker lights. I have them wired to the marker lights currently and I have used FORscan to have the marker lights come on with the DRL's. It works for now, eventually I will be getting Aux switches and wiring them through there instead.
I haven't wired it in yet, but they also have a sweeping motion from front to back when the turn signal is put on.
bigb
Tucson
2025 Ranger 2.7
I'm getting to hate my running boards more and more. I think I'll either remove them and get ppf or try a set like @dc73pdsgt has. I saw a Ranger today without running boards and I thought it looked pretty nice.
