Strands Nuuk D-line 40” behind RR grill
CHall
chris
Nashville
2024 Rsnger Raptor
2.5hr install so far. Still have to final wire everything. Probably be asking for wiring help after some searching.
Wanting smber DRL on with factory headlight DRL’s, Aux switch 6 or 1 turns on light bar and light bar lights up with high beams only and only if aux switches on.
Waiting on Signature Lux Amber DRL circuit boards before removing anymore parts again. Just ziptied wiring up out of way while wexwsit
Ford Ranger Strands Nuuk D-line 40” behind RR grill IMG_6926
Ford Ranger Strands Nuuk D-line 40” behind RR grill IMG_6921
Ford Ranger Strands Nuuk D-line 40” behind RR grill IMG_6928
Very happy with fit. Alignment of amber DRL with factory headlight DRL was the goal. Minor trimming necessary.
Ford Ranger Strands Nuuk D-line 40” behind RR grill IMG_6931
HGHVLTS
24 Integra Type S, 65 Mustang Fastback, 71 Skyline 2000GT, 72 Celica ST
Electric System Operator
Looks clean, like the look, any way you could do some light output pics at night? Wouldn't mind seeing how they light up the road!
entoptics
Pac NW
2024 RR
Looks good!
How did you achieve the holy grail of tying the lights to high beams??? I’ve searched high and low for instructions. Even my Ford dealer couldn’t (wouldn’t?) help.
I've got the Altiq bar, and they were no help either.
Dog hits the AUX switch with her head every once in awhile, so I blind people too often. Even got pulled over for it awhile back.
Would love some details on the wiring recipe!
CHall
chris
Nashville
2024 Rsnger Raptor
I have not completed the wiring. So far looks like pin 3 will be my trigger wire for high beams. Headlight Pin 6 will be DRL trigger. Also think I’ll forego using any factory upfitter switches and be wiring direct to battery with a 40amp fuse.
I’ll report back when I complete the permanent wiring.
entoptics
Pac NW
2024 RR
Hope I'm wrong, but be prepared for disappointment.
I don't remember the exact pins I was instructed to use, but there was no 12V signal that comes/goes with the high beams on any of the pins when I tried to wire mine up.
Apparently the "Rest of the World" rangers have a different setup, and at least in Australia, the AUX6 switch is tied to the high beams from the factory, but not the NA Raptors.
There's supposedly a wire in the cabin somewhere (driver footwell?) that carries a voltage when the highbeams are on, but I've not found much information to locate/ID it.
CHall
chris
Nashville
2024 Rsnger Raptor
I tested every pin in headlight harness and you’re right, I got not voltage to tie into high beams. Ended up using Aux 1 to trigger light bar which does work fine.
CHall
chris
Nashville
2024 Rsnger Raptor
I used some parts from the supplied end brackets and powder coated brackets I had from a TV mount to shim alignment to DRLs.
Thru-bolted on plastic subframe structure.
Ford Ranger Strands Nuuk D-line 40” behind RR grill IMG_6923
CHall
chris
Nashville
2024 Rsnger Raptor
Haha, quite a difference in the 4 pictures. I’ll give you those pics do not show any distance.
19,600 actual lumens @ 1 LUX at 1900’ pulling 200watts.. On the interstate the entire road is illuminated with just the light bar.
Once there’s less daylight hours I’ll do some adjustment vertical. Left/right aim is perfect, but vertical needs to be adjusted.
