Tranny and wierd noise questions
JR RANGER
JR
Auburn CA
2024 Ranger XLT FX4 4x4
JR Ranger Does anyone feel the shifts in the 5 lower gears. I've got a 2024 Ranger XLT FX4 4X4 2.3 with 3k miles on it. My shifts are not rough but not as smooth as the the top 5 gears? Second question when I'm cruising on the freeway 70mph I hear a faint almost grinding sound ( like bad bearing rubbing sound). Seem to increase the faster I go. Haven't scheduled an appointment with the dealer yet. Wanted to see if anyone else noticed this.
Thanks for your response
JRRANGER
stuartmunto
Stuart
Perth, Western Australia
2023 Ford Ranger Raptor
There was a small number of very first next gen Rangers over here in Australia that had low rear diff oil added in from factory. Some rear diffs needed to be replaced due to damage. This has no longer been a thing since early 2023, however it may still happen as manufacturing is still fairly new for the US market
Symptoms were the exact sounds you're describing. 100% worth taking it in to get looked at asap
check out this video:
Ford Motor Company
Official Ford Account
Ford
Dearborn, MI
Ford Ranger
JRRANGER
Good afternoon! If you'd like to, go ahead and send us a private message with your VIN and dealer info and I’ll look into these concerns. Thanks!
JR RANGER
JR RANGER
JR
Auburn CA
How do you send a private message?
JR RANGER
JR RANGER
JR
Auburn CA
JRRANGER
JRRANGER
Update took truck to dealership turned out it was a bad front wheel bearing which was replaced under warranty. They also reflashed the transmission what a difference. All is good now.
JR RANGER
JR RANGER
JR
Auburn CA
JRRANGER
Took it to the dealer and turned out to be a bad front hub/wheel bearing. Coveted under warranty. All good again.
