Transmission Pan replacement?
YukonRanger
Yukon
any 10R80 or 10R60 replacement pan will work.
I like the mishimoto but im worried it might not fit skid plates
Johnnycrane
L4L 3L8
2024 Ford Ranger Lariat 2.7L Twin Turbo
Dorman has a replacement trans pan with drain plug
265-897
Transmission Oil Pan
RCMUSTANG
Ray
Los Angeles
1989 Mustang 2017 Fusion
Saved my PPE from my 2019 to reuse on my raptor whenever it arrives.
Buellsox
Scott
Tacoma, WA
Local 26 Union Plumber
I did the PPE with the 2 qt. extra capacity on my previous ‘19 F-150. Did it myself with the truck on ramps. That pan is hell for stout! Pan itself weight 3-4lbs. - solid aluminum. Never gave me an ounce of trouble when torque sequenced correctly. I ordered the kit through PPE so it came with Ford Motorcraft ATF, Motorcraft filter, and a Ford part numbered pan gasket.
Great kit. Really easy process to do yourself and these Rangers really have easy access to the pan. I carefully drilled a whole in the lower corner to drain the pan (since there’s no plug) since I was tossing it anyways.
It’s the only kit I’ll consider when I do my RR pan & trans service at 10K. I’ll do the same 2 extra qt. capacity for more filtration & cooling. No reason not to, plenty of room.
