Water intrusion in the bed
my5thranger
Northwest Arkansas
2025 Ranger XLT
I wonder if expanding foam would work under the bed rail caps and in those two large cavities in the top corners of the front of the bed? Maybe that would help with water intrusion. Not sure how chemicals in the foam would affect painted metal.
hand-filer
That could end up creating a moisture trap that could eventually convert perfectly good steel into iron oxide.
cforput77
Craig
2024 Ford Ranger XLT 4WD
I have been wondering the same thing. And I'm not sure I'd agree. Any method anyone has posted about sealing things up potentially has this water trapping / rust issue. What makes sealing foam so different? If everything is dry and you apply the foam, it probably gets a better "fit" that any other method up in the 2 large cavities the OP mentions. I am curious about the chemical makeup of the foam and if it would be too caustic for the paint.
