What's your oil temp range?
Oval6G
Wayne
My 2024 RR has about 8K miles. Oil temp ranges between 200 -235. Normally closer to 200 but spikes and varies a lot. Seems high to me so curious what others are seeing?
Thanks
Blue_Raptor
Simi Valley, CA
Once fully warmed I generally see 190 (maybe after coasting down a hill a bit) to 220 or so. Flat ground, highway speed its usually around 210 maybe a little lower. But now that summer temps are coming, Ill see if my averages trend a little higher.
stuartmunto
Stuart
Perth, Western Australia
2023 Ford Ranger Raptor
I was always told that 90c - 110c (190f - 230f) is normal temp range and where modern oil is designed to offer best protection
This may give or take depending on oil grade (eg: 5w 30 etc)
Seems like you’re running right in the middle of that range
