Wheels offset question.
Cronk
NE
2026 Ford Ranger XLT 2.7
For a '26 XLT V6. Looking to put 17x8.5 Fuel Anza wheels with a 275/70-17 Falken Wildpeak. Anyone know if the +6mm offset will clear the suspension components or would I need to go to the -6mm offset?
ryanO
Ryan
2025 RangerXLT
Sales
i highly doubt the +6 will allow for your tires to clear the fenders without serious modifications including at least a 2" lift and trimming, never mind going to the -6. The clearing of suspension is a whole other conversation.
Cronk
NE
I'm planning on eibach pro truck stage 2 level/lift kit. Would that still require trimming? Thanks for your input, I just went from an F-150 to the ranger and don't know much about it.
ryanO
Ryan
2025 RangerXLT
Sales
I only know of a guy that's running 0 offset with 285/70/17 and he had to remove the crash bars even with a 2" lift. I imagine it'll be VERY close at best with the +6 and I cant imagine it works at all with the -6.
You're planning a slightly smaller tire but that offset is really aggressive. Most are running either +35 or +25 at most.
I'd say try it with the +6 but be prepared to have to go with a less aggressive offset or do a good bit of trimming and assume you'll never get away with -6 unless you do a 6" lift.
ryanO
Ryan
2025 RangerXLT
Sales
Think of it this way, at a +6 vs a +25 you're pushing that wheel out another almost 3/4" and that drastically changes the pivot point.
The stock wheels are +55 so that vs a +6 is nearly 2" further out plus your tire is going to be bigger.
If it works, post pics please! I'd love for it to work.
OxygenMask
Phil
Eugene, Oregon
Those offsets will stick out 2 to 3 inches more than stock - not gonna work.
(NEVER accept an online wheel store stating a wheel is a good fit for a particular vehicle especially trucks. All they look at is bolt pattern, never whether the offset is reasonable.
Find a wheel and tire size comparison tool and use that plus your own tape measure.
Also be aware of the swing when turning lock to lock.
First one I found, there are better ones...
https://variantwheels.com/pages/cal...CM_Rxl0vDw4iluvr1pO-Vgo92hiOqOTWr44X7wpXmIGfD
Tons of threads on this forum with wheel & tire combos listed that fit, usually with pictures.
Cronk
NE
Thanks everyone for your input . Much appreciated.
ryanO
Ryan
2025 RangerXLT
Sales
Those offsets will stick out 4 to 5 inches more than stock - not gonna work.
I agree here. Wasn't gonna totally dash his hopes...lol.
Between the 2" offset gain and the 1" wheel width gain plus the wider tire, there's just no way.
ryanO
Ryan
2025 RangerXLT
Sales
Anytime! Everyone here is super helpful. Grab a +35 or +25 offset wheel with that tire size and the 2" lift. You'll be set!
As many have said I doubt the +6 would work. Pretty much sure the -6 would not work.
Max offset I would ever consider is a +25.
I am running a +30 now which fit fine and I would say + 35 would be even better or the perfect offset IMO.
ryanO
Ryan
2025 RangerXLT
Sales
On your +30s, do you have any rubbing at full lock or compression?
I'm about to pull the trigger on the new FOX 2.0 coilovers and a set of Bronco Sasquatch take offs. They are +30 and I'm thinking of just changing out the crash bars anyway to the aftermarket modified ones.
No, not with the stock 285/70R17 tires.
‘I had a very slight rub with front crash bars in reverse at full lock with the 295/70R17s I started with.
djrainmann
Aaron
North Las Vegas
2025 Ford Ranger Lariat Fx4
LMS Admin
25 Lariat here with Eibach Pro_truck Lift Stage 2 Coilver setup.
2.5inch lift in front running 285/60R18 Fuel Rincon 18x9 rims with -12mm Offset and I barely rub exept when in reverse and full lock right side. The rub s ever so slite, nothing cut out.
Cronk
NE
2.5inch lift in front running 285/60R18 Fuel Rincon 18x9 rims with -12mm Offset and I barely rub exept when in reverse and full lock right side. The rub s ever so slite, nothing cut cut out.
Thanks for the info.
TexasTurner
Michael
Oklahoma
I'm about to run a similar set up. Did you get new upper control arms as well? or just stick with the stock UCA?
