Where should these lines connect in engine bay?
WarScar
RhodeIsland
I recently took delivery of my 2025 Ranger Raptor was checking fluids and noticed two unhooked connectors left side is drawing vacuum when vehicle is running. The right side doesn't have any vacuum. I looked all around the area and cannot find where they should go. Does anyone know where they should be connected?
Ford Ranger Where should these lines connect in engine bay? 20250621_123430
Bagman51
Bob
Ontario, Canada
2024 Ranger XLT Sport
Mechanic, retired
Based on one is male and other female? Do the connection!
WarScar
RhodeIsland
Unfortunately they don't fit together. The connectors are incompatible.
Deleted member 850
Checked my engine bay. Don’t see anything like that!
Blue Ridge Raptor
North Georgia
If it’s practical - consider going to the dealer and compare yours to one sitting on the lot. If a new one has the hose and yours doesn’t, then your problem is solved & the dealer should just order the hose.
i would go out and look at mine, but my wife took off with it this morning.?
Deleted member 850
Not sure about where you live, but I’ve never seen a Ranger Raptor sitting on a Dealer lot. They’re sold befioe they arrive in most cases.
WarScar
RhodeIsland
I exhausted google searching, looks like it is an extra vacuum line. I don't see any other with that line. Wondering if they accidentally installed an incorrect line instead of a cap. My plan is to find another new one and compare.
Does anyone know if there is a port / cap in the area that this line is connected on their raptor?
WarScar
RhodeIsland
Can anyone share a photo of how theirs looks if they don't have the same line?
Dre' Dawg
Andre'
Magnolia, Texas
I checked engine as well and don't see anything like that. I included a picture for you to look over.
Ford Ranger Where should these lines connect in engine bay? Raptor Engine 6.23.25
WarScar
RhodeIsland
Thank you, that photo is a bit too far forward. It's behind the top center pipe, not the ones with out the R & L on them.
Dre' Dawg
Andre'
Magnolia, Texas
I took two more shots one further back and one of where they went to. Let me know if you need
more infor
Ford Ranger Where should these lines connect in engine bay? Raptor Engine Vacumn line1
Ford Ranger Where should these lines connect in engine bay? Raptor Engine Vacumn line2
WarScar
RhodeIsland
This is where this line connects the white circle. Looks like you don't have a line off it. My line does not connect to anything which makes be belive it was a factory error and needs to be capped. Is there a cap on this spot on yours or solid plastic?
Ford Ranger Where should these lines connect in engine bay? Screenshot_20250623_125736_Edg
Dre' Dawg
Andre'
Magnolia, Texas
What you circled is a 2 port electrical connection, no vacuum lines. I took a closer shot of my set up. When did you order and take delivery of your RR. It appears they made a change to their vacumm setup. Good luck let me know if you need more pics.
Ford Ranger Where should these lines connect in engine bay? Raptor Engine Vacumn line close u
WarScar
RhodeIsland
My build date was 3/25. This area where circled looks the same as yours but just has a line connected. The electrical lines sit next to it. Possible to take a top down photo?
Dre' Dawg
Andre'
Magnolia, Texas
It looks like the capped a nipple where they tapped the vacuum. It is a hard plastic cap and hard to get a good pic of it.... 3 attached.
Ford Ranger Where should these lines connect in engine bay? Raptor Engine Vacumn line close up 2 of 3
Ford Ranger Where should these lines connect in engine bay? Raptor Engine Vacumn line close up 3 of 3
Ford Ranger Where should these lines connect in engine bay? Raptor Engine Vacumn line close up3
