joecounty2025
joe
texas
2024 ford ranger xl stx 4x4
friend was asking me this morning ,if for some reason you was to accidently over fill the engine with oil,can he use the siphon contraption that looks like a syringe with a little tube? will the tube go all the way into the oil pan through the dipstick tube?
Reactions: Doc
joecounty2025
joecounty2025
joe
texas
What size of tube would he need?
Reactions: Doc
ChronciallyChronic
Central Florida
2024 Ford Ranger Lariat
He over filled the engine oil, eh?
Reactions: Doc
stuartmunto
Stuart
Perth, Western Australia
2023 Ford Ranger Raptor
What ever fits I guess? Just buy an assortment of flexible tubes from the hardware store? Or measure the size of the dipstick for a rough idea?? It's not rocket science - just slowly feed a tube in until it stops, pull some oil out, rinse and repeat until optimum oil level is achieved
Reactions: Doc
snowman3
us
none
And I don't know much about much. But I assume would want to take off the filler cap "add oil here" where you added the oil. That way sucking from dipstick won't create a vacuum inside engine.
I've heard of bad shops sucking out oil rather than use drain plug. I don't know how much vacuum would need to put on dipstick to raise the oil ~2 feet. Might not even need to insert tube.
joecounty2025
joecounty2025
joe
texas
Ok thank you, I will tell him about that
stuartmunto
Stuart
Oil extraction is normal on a lot of Euro designed engines. Nothing wrong with it if done right. There won't be a vacuum in the engine when extracting oil as the tube going down the dipstick port doesn't create an airtight seal. I wouldn't be sticking any tubes in to the oil fill port, the dipstick port is designed to have a clear run to the bottom of the oil sump without hitting any parts/components (IE: the dipstick safely sits there, so no risk in putting a soft flexible tube down there too)
joecounty2025
joecounty2025
joe
texas
But to be safe he should take off the oil fill cap, right? When siphoning the oil?
