2024 Ranger Bed Cap "shims"
Stu x 4
Stu
Have order in for 2024 Lariat Ranger Fx4 2.7L and talking with ARE dealer, the plastic bed rails will not support a topper. Ford engineers are aware.
ARE Dealer said ARE toppers now have a bracket shim for the bed rail issue, so all new toppers will come with that. The Load Reinforcement brackets will still need to be needed as noted on this forum. I would say that service departments are charging for that, Ford dealer knew I was going to put a topper on so I've alreay asked sales guy to make sure that he includes that in the truck deal.
Placed order for vehicle 5/3 and still don't have a build date yet...looks like I'm waiting on allowcation.
ARE CX Revo, bed rug and Yakima rails in my future too...will post picks somewhere down the line. Like most folks, now that I have an order in, I want it yesterday!
Can you please provide a link to some actual documentation from FORD that says that the plastic rail caps are not able to support the load of a topper? This is the first I have heard of it!
This did not affect the 5G trucks, see this thread, Wes Siler’s post #14:
https://www.ranger5g.com/forum/threads/bed-rail-weight-limit.25636/
I have a Go Fast Campers Topper on order, and they assured me in an email that they mount them directly on top of the plastic rails. As an ex A&P tech, that sounds like a very fishy installation, but I believe that it is standard practice.
Unless there is some official documentation from Ford, I am calling this issue to be bogus.
Thanks!
Spokane WA
Stu x 4
Stu x 4
Stu
Then there is this...see pic.
When the dealer first told me about this, I went back to dealership to take a gander. Took pic of 24 Ranger, can't speak to the 5G.
You got me courious. When the dealer opens up on Monday I'll ask. For now, I'll belive my eyes and the dealer.
Ford Ranger 2024 Ranger Bed Cap "shims" 1719038076056-2m
Richie
Richie
24 Ranger Raptor, 21 X5 M50i
I currently have a soft topper installed directly over the bed rail caps.
I have an Alu-cab canopy on order and they have informed me that the canopy will come with replacement bed rail caps that need to be installed before the canopy can be mounted. I will share photos after installation.
dfritz
Doug
Western Colorado
I've been thinking on this issue so I can make a rack and some tube bed rail protectors and tie offs. What I've seen is some commercial units bolt into the sides and not rest on top. The actual removable covers reveal some unfortunate measurements for inserting a shim and securing it or using it for support. A few remove the plastic molding completely and mount directly on the bed rail. Another factor is the overall build of the bed. If you've ever seen trucks with cracks in the side of the bed behind the cab from tool boxes or racks, stand by. I think the new Ranger is going to be particularly prone to spreading and cracks.
This is obviously a non structural, purely decorative cap, it is 98% air underneath. There need to be three steel shims about 7/8” tall on each rail, down in those pockets to support the load. Or remove the plastic entirely. If the latter, I will be REALLY pissed, because I just had a Line-X coating installed and I specifically asked for him to remove the caps first, and he said “We never do that, we just spray up under them.”
Ford Ranger 2024 Ranger Bed Cap "shims" IMG_6998
Ford Ranger 2024 Ranger Bed Cap "shims" IMG_6996
Ford Ranger 2024 Ranger Bed Cap "shims" IMG_6993
GLW
Missouri
I ordered and installed Retrax Pro XR bed cover. In the kit came four brackets that supports the cover above the plastic. Worked well.
Ford Ranger 2024 Ranger Bed Cap "shims" IMG_4524
Finally found mention of “spacers”, in the Smartcap instructions. They also use brackets in the corners that bolt to the bed.
Ford Ranger 2024 Ranger Bed Cap "shims" IMG_6758
Ford Ranger 2024 Ranger Bed Cap "shims" IMG_6759
ARB for their canopies is VERY adamant about removing the moldings entirely. I wonder how the Leer ones are mounted?
I mocked up some spacers to see how tall they would need to be, I come up with a little under 0.827”. I might try making some from 1.5” diameter acetyl rod on my mini lathe. Two discs dropped into each cavity should stay in place by gravity and fill up the spot.
Ford Ranger 2024 Ranger Bed Cap "shims" IMG_7004
Ford Ranger 2024 Ranger Bed Cap "shims" IMG_7003
Ford Ranger 2024 Ranger Bed Cap "shims" IMG_7002
Helena-disappointed
Norm
Montana
24 Ranger XL
When I called my local Helena MT topper dealer on 7-1-24 to find out about toppers for my new 2024 Ranger XL 4x4, he said he can't sell them because Rangers can't have > greater than 88 lbs on the bed rails without a $169 (part only) retrofit of "J" brackets. I called my local Ford dealer, & its parts guy said I need to order 2 of them. I am not sure that's correct. Installation on Ford's website seems to be an addl $192. This was not disclosed in any Ford literature I saw about Rangers, & is not stated in the owners' manual or anywhere but this forum. How can Ford sell a midsize pickup truck without one of the most basic fxns- capability of adding a topper w/o expensive modifications- unless it discloses this to potential buyers?
Stu x 4
Stu x 4
Stu
And to think...even if you did not want a topper and were at an event, tailgating with people sitting on the rails, it would exceed the load capabilities of the bed/plastic covers with only one person. :>(
Anyone have any updates on the shims? Are they required for campers? know anyone who sells em?
GoFastCampers came up with their own design, you might email them to see if they will sell you a set. This pic is from a member here who posted at the GFC Forum.
Ford Ranger 2024 Ranger Bed Cap "shims" IMG_7248
https://forum.gofastcampers.com/t/2024-ranger-raptor-installation-gfc-question/28921/9
I am not sure why they felt the need to use two monster 12 mm bolts per spacer, and those huge recesses will just trap moisture. If the spacers were made of plastic, that would be a non issue. Aluminum on steel plus water equals corrosion! I would invert them and use 3M double sided tape underneath and clear single sided tape on top to correct that problem. They won’t go anywhere once your accessory is in place.
CrudeBacon77
Ranger Lariat FX4
I may just email them since there is still no word on J braces. Been waiting a couple months now. Still nothing from Ford.
Mlowery1
California
Ranger Lariat
Anyone have an update on these spacers?
i am trying to install an Xtrusion overland rack and was thinking that spacers would definitely be needed as the brackets are nearly directly over the stake hole area.
