2025 RR Long commute and body aches
Mikey'sRR2025
mike
NC
Ford Ranger Raptor
construction
Sorry Mikey. Just trying to make light of the situation. If you've already lowered the air pressure to 39 or below, I'm not sure much else can be done to make the truck comfortable to your level. And just to be clear, you are on the "normal" ride setting, correct?
Yes all settings are set to use on highway
Normal, comfort steering
There is definitely a vibration and I have seen a couple of buyback resales due to vibration hence
Is this your first truck? What were your last 3 vehicles if you will kind sir?
last 3 2024 Nissan Frontier Pro4 X
RR XLT CC F X 4 2012 and 2023
Mikey'sRR2025
mike
NC
Ford Ranger Raptor
construction
I will thanks
Daweism
Austin, TX
See if maybe your wheels aren't proper balanced
Fawnbuster
Indiana
Picked up 2025 RR in White
Great looking truck
Heard they suffer from vibrations I have already lowered tire pressures that came at 46Ibs and had dealer re balance but man my torso aches from driving as you can feel the vibrations in the seat of your pants
Anyone else
Thanks
My 2019 came with 50psi, dealer didn't check it. When I did a level lift and new shocks, uca's and went up to 285 70 17 WildPeak tires i started at 40 psi (I ran 40 in my take home police car with all of my regular gear plus allergy of my scuba gear it handled perfectly) but 40 was a bit hard on my back after a while so I lowered to 35 psi cold and it was alot more comfortable. I have a bad back, 3 surgeries including 2 total disc replacement's and ablations and 2 total knees. I feel your pain. Although my 19 was as close to a RR as I wanted to get, the test drive in the 2025 RR on my local daily driven streets with all of the bumps, it rode better than my 19 Lariat and better than my wife's Lincoln MKX! I don't know what psi was set at and I didn't think to see what settings the steering was set at from the factory, I don't recall seeing a 4H icon lit up. I would try 35psi cold, 2H, and different modes, normal, sport etc, leaving your seat at a preferred comfort setting and drive the same roads for a day before you make changes. I had just had my 1st (right) knee replacement before I retired so I was on desk duty driving my 19 Ranger back and forth to work at the Sheriff's Office, only 10 minute's but I couldn't get comfortable at all for a while. An hour drive to deer camp was a killer but after my knee, back and hips learned to get along it was much better. I did have a coccyx seat cushion and an added lumbar pillow, the oem lumbar didn't hit me in the right spot post op.
RaptorBlue
Chad
SW Florida
2021 Ranger Tremor/2023 Bronco Badlands
Ford salesman
I
It rides worse than a Frontier?...yeah, there is a problem with your RR. Sounds like a trip to a trusted dealer is in order.
Mikey'sRR2025
mike
NC
Ford Ranger Raptor
construction
Will do a trip to dealer tomorrow
Will keep you all posted
I have had wheels rebalanced and all setting set to best ride possible
The drivetrain is where the vibration is
RonM_TX
Ron
Conroe Tx
Is the vibration constant, vary with speed or vibration only at certain speed? Also do you feel in the steering wheel or the seat or both? Just asking as they will help the mechanic pinpoint the source.
I had a similar issue with vibration soon after buying new tires. Tire shop balanced the tires 4 times then admitted three of the tires were out of round causing a varying vibration.
All replaced resolved the problem.
OXDOG27
Arizona
Great looking truck
Anyone else
Thanks
OXDOG27
Arizona
Great looking truck
Anyone else
Thanks
We just drove from Arizona to Michigan, 2000 miles for the second time. A very comfortable ride for small truck built for off road.
LDHunter
Bob
NW Florida
Real Estate
So did you come to this conclusion because the vibration varies with the amount of throttle you're giving it?
Is it better or worse in corners?
How about when the tires are cold vs. hot?
Mikey'sRR2025
mike
NC
Ford Ranger Raptor
construction
Thanks for this
It’s more in seat than wheel and between 50-65 drove to Boston and body was still moving after I stopped for quite a while
And I already had the wheels balanced at 100 miles
Was exhausted
Took it to dealership yesterday 2nd time
They rotated the tires, checked pressures and put a sensor on 4 wheels for sound/vibrations and checked that all suspension etc was tight
It’s still there 50-65 slightly on wheel and in the seat, you can feel it in the legs
It’s so slight but it’s there
Thanks for all your responses everyone
It now has 2400 miles
Tires have been rebalance and now rotated X wise do fronts are on back etc
Fawnbuster
Indiana
Thanks for this
Was exhausted
Road force balancing cured all of my vibrations.Discount tire did mine.
RonM_TX
Ron
Conroe Tx
Thanks for this
Was exhausted
At this speed it could be the driveshaft being out of balance. You have not said if any of the tire rebalancing has made any difference. If not its time to start looking elsewhere.
mAtTyG04
Matthew Glazier
Edmonton
2025 Raptor Ranger
Exact truck down to the color. 34 front and 32 rear psi cold.
Fix4Dirt
SLO County, CA
'24 Rngr XLT FX4, '98 Xplorer XLT 4x4 SOHC
Physics Researcher/Welding Teaching Assistant/Auto Detailer
Great looking truck
Anyone else
Thanks
Not an RR but I havent noticed that in this one. This one is very comfortable to me. COmpared to the other fullsizes Ive deiven like a cateye Silverado (granted that was a bench) this is very comfortable. Its no Deville, but its more than comfortable for me.
