unsavory
- Thread starter
- #1
Hi folks, got these DG support bars for my 25RR. Was concerned about loading my 500+lb moto when open weight rating is 485lb (according to online manual)
Google search says most trucks tailgates rating maxes out about 500lb for evenly distributed loads specifically when ramping it up using throttle and engine, have to hit tailgate with some, but not too much momentum and the instantaneous force will definitely exceed the tailgate rating
I havent had a problem so far with this and heavier bikes on this and other trucks
I never charged at the tailgate hard with be bike
DG website only lists ones for the 25 maverick so i ordered but they turned out to be too long, 27 iirc
After some back and forth and measuring with friendly owner he suggested the ones for a 2015 chevy colorado, they are about 25" center to center
(I don't have any links handy)
Well, I tried them and they engage the weight before the cables do, so if anyone else is interested. I was the guinea pig
I don't know what weight rating of the new setup is, but it has to me more than a crimped cable and cables are still there as secondary
I haven't had a chance to use them, but I will next time I truck the 2020 ktm 1290 super adventure r (I like bike, currently in shop for punctured radiator, rock got wedged in between engines somehow)
I'm storing then under the rear seat in the heavy plastic sleeve they came in and it seems to close ok
I have multiple trailers and moto carrier too and don't always put the heavy bike in bed
People do harleys and other heavier bikes too and I haven't read (or searched for) horror stories of failures from going over tailgate ratings, but I have more piece of mind for about $112 otd
Side story: I actually broke most of the tack welds on the aluminum ramps and bent the sheet metal even though they are rated for 750 each (others suggested bend sheet back, drill and screw fix, also on the endless project list). Ramps themselves feel pretty flimsy, suggest others get the ladder style (non sheet), There are higher wt rated ramps avail, mine were pretty cheap $130 when I got them 6 years ago
