275/70R18 = 33.2"X11" Best option for the FX4?
jeffers
Jeffrey
Nevada
2024 Ranger FX4, Mk7 GTI
This size would give an increase of 1.05" in tire radius and require about a 1.5" lift. I'm thinking this might be the best option for the FX4.
Any thoughts?
For reference stock FX4 tires are 255/70R17 = 31.1"X10"
stock Raptor 285/70r17 = 32.8X11.5
jeffers
Jeffrey
Nevada
Possible tire options
Falken Wildpeak AT 275/70 R18
Cooper STT Pro AT 275/70 R18
jeffers
Jeffrey
Nevada
Great, I can't find any 18" rims that say they fit the 2024 Ranger. If you go on Tire Rack or Discount Tire they don't have anything listed under the new Ranger. It seems our trucks are too new for any aftermarket support. I noticed the Bronco has different offset requirements from our Rangers so thats a no go too. I noticed the Lariat comes with 18" wheels so eventually there should be aftermarket support.
Catalyst
Justin
Bend, OR USA
Network Engineer
There are many 18" wheels that suit the '24 Ranger. TireRack doesn't have the 6th Gen Ranger(s) in their database yet - but there are many other places that do. As a future Raptor owner I don't know as much about fitment with the standard FX4 Rangers, but there are some others who had done a lift and larger tires on the site here. I suspect you will need offset around +35 to+55 with an 8"-8.5" wide wheel with the modest lift you are discussing to keep it within the fenders.
Just google (example: 18x8.5 6x139.7 PCD wheels) and you will find many options. Method, Icon, RTR, etc. all make wheels that fit. Also CJPonyParts has some options from the Ford Performance/Roush catalogs as well.
jeffers
Jeffrey
Nevada
cool thanks
jeffers
Jeffrey
Nevada
So far I've come up with these wheels. opinions? Americantrucks.com has the Ranger loaded into their system.
Ford Ranger 275/70R18 = 33.2"X11" Best option for the FX4? raceline_942B_ADDICT_Black_Addict_(black_6_1
Ford Ranger 275/70R18 = 33.2"X11" Best option for the FX4? kmc-24ranger-grenade-off-road-matte-black-wheel-18x85-35mm-offset-km53588568735.CT8727G07
Ford Ranger 275/70R18 = 33.2"X11" Best option for the FX4? method-race-wheels-24ranger-mr318-gloss-black-wheel-18x85-40mm-offset-mr318885601340.CT14648G07
Ford Ranger 275/70R18 = 33.2"X11" Best option for the FX4? american-racing-24ranger-ar916-satin-black-dark-tint-clear-coat-wheel-18x85-ar91688568935.CT2
Ford Ranger 275/70R18 = 33.2"X11" Best option for the FX4? Large-havasu-truck-wheels-rims-black-rhino-havasu-5-lug-matte-black-std-png_b95bd9ac-487c-4fd
engus13
Clemmons, NC
2024 Ford Ranger Lariat Fx4
What american racing wheel are those?
Freedom Beast
James
2024 Ford Ranger XLT FX4
I have one
Gonna piggy-back off this and ask - is there that much difference between a 17x8.5 and an 18x9 wheel? With these trucks, do I want to stay with the 8.5 width? Method makes a killer looking wheel I want but only comes in 18x9 +18. It does come in a 17x8.5 +25, but I like the look of the 18s a little better. Thx
jeffers
Jeffrey
Nevada
I think 285/65R18 gives you the same size as the RR tire. You'll get better on road performance but will have less sidewall for offroad. Its pretty equivalent to the RR and significantly bigger than the stock FX4 tire.
-corrected
I'm looking at 275/70R18 because it will give a full one inch more ground clearance over the stock FX4 tire and will help you roll over obstacles. Its a true 33" tire, and I think should fit with only a 1 to 2 inch lift. I think any bigger and you're going to have to start making pretty significant modifications.
Ford Ranger 275/70R18 = 33.2"X11" Best option for the FX4? Screenshot_31-8-2024_9641_tiresize.com
jeffers
Jeffrey
Nevada
What size tire are you planning on getting?
Freedom Beast
James
I have one
285/65r18 - Hoping Fox comes out with a 2" coilover kit. I currently have a factory 2.5" rake and the 2" level would leave me .5" rake for hauling. That's the hope anyway
jeffers
Jeffrey
Nevada
Sounds right
jeffers
Jeffrey
Nevada
I'm not sure +40 offset is enough. Here's a picture of them with a 3/4" wide straight edge, the suspension is at fool droop. I measured 9/16" between the straight edge and where the knuckle connects to the control arm. The rim is 18"X8.5" +40mm
I'd really prefer not to have to add wheel spacers.
Ford Ranger 275/70R18 = 33.2"X11" Best option for the FX4? PXL_20240901_190733674.LONG_EXPOSURE-01.COVER
Ford Ranger 275/70R18 = 33.2"X11" Best option for the FX4? PXL_20240901_184805080
Ford Ranger 275/70R18 = 33.2"X11" Best option for the FX4? PXL_20240901_183351278.MP
jeffers
Jeffrey
Nevada
I think I recommend going with the +35 offset.
jeffers
Jeffrey
Nevada
Yeah, if you look at the curve of the RR steering knuckle I think its completely different from the FX4. Anything close to the RR's +55 isn't going to work.
Ford Ranger 275/70R18 = 33.2"X11" Best option for the FX4? 20240314-131457-65fb8a2f39ffd
Ford Ranger 275/70R18 = 33.2"X11" Best option for the FX4? PXL_20240901_214237626.MP (1)
