Narwhal Truck Toppers
Richie
24 Ranger Raptor, 21 X5 M50i
Ranger 6G Friends,
We threw the biggest rooftop tent we could find on top of the topper for this test, adding roughly 200 lbs of additional dynamic load while the truck is fully articulating. If the material was going to crack or deform, this is where you'd find out.
The thing that most people get wrong when they spec a topper is they treat it like a static structure sitting on a dynamic truck. Your bed is moving. A lot. Especially on a Raptor with the suspension doing its thing. If your topper is fighting that movement, you're going to end up with stress cracks, deformed panels, or a topper that's slowly eating itself on every trail. Add a couple of hundred pounds of tent on top, and you've accelerated that failure timeline significantly.
What we engineered into the Narwhal is flex in the composite layup itself. The carbon fiber is designed to move with the bed during articulation rather than resist it. That's not a marketing line, that's literally how we spec'd the material. The result is no cracking, no deformation, and a structure that stays intact after miles of actual off-road use, even fully loaded.
Weight is the other piece. Less mass up high means the suspension can do its job without having to compensate for what's on top of the bed. You won't need a spring upgrade to accommodate this topper, and you won't even notice it on the back of the truck when you're getting after it off-road.
Hit us up if you have questions, and we will be sharing a lot more info about the production launch in June, as well as inviting people to come see the topper in person at our new facility near Denver, CO!
Cheers,
Richie
The original zelda was the best. We played the heck out of that and mike tyson's punch out
